Windows 10: Problem with Realtek R Audio Driver; after restarting computer devices go mute again
Discus and support Problem with Realtek R Audio Driver; after restarting computer devices go mute again in Windows 10 Drivers and Hardware to solve the problem; Hello, I have a problem with a Realtek R Audio Driver. Every time after I deinstall it and reinstall it to fix sound problems, I have to move the... Discussion in 'Windows 10 Drivers and Hardware' started by Małgorzatta, Oct 31, 2020.
Problem with Realtek R Audio Driver; after restarting computer devices go mute again - Similar Threads - Problem Realtek Audio
Where did Realtek R audio go?
in Windows 10 GamingWhere did Realtek R audio go?: Note: This happened just after performing a clean installation of windows 11Help, I need the Realtek R audio driver back not the Realtek High Definition Audio as it is constantly messing with my headphones in terms of surround sound being exaggerated and the Realtek audio... -
in Windows 10 Software and AppsWhere did Realtek R audio go?: Note: This happened just after performing a clean installation of windows 11Help, I need the Realtek R audio driver back not the Realtek High Definition Audio as it is constantly messing with my headphones in terms of surround sound being exaggerated and the Realtek audio... -
Realtek R Audio missing in device manager
in Windows 10 Software and AppsRealtek R Audio missing in device manager: My realtekR audio driver gone missing after i miss install another audio driver and the new driver didnt function at all. After i uninstall the wrong one, the realtekR audio did not appear again in my device manager. I try to find it but it gone missing. I've tried to add... -
in Windows 10 Drivers and HardwareRealtek R Audio missing in device manager: My realtekR audio driver gone missing after i miss install another audio driver and the new driver didnt function at all. After i uninstall the wrong one, the realtekR audio did not appear again in my device manager. I try to find it but it gone missing. I've tried to add... -
My realtek r audio driver is not working .
in Windows 10 Drivers and HardwareMy realtek r audio driver is not working .: I have to shut down my device and then plug my earphones then it works , but if i unplug when the laptop is switched on and then plug it it will not work . i have to restart my device to do that . I have checked it in driver updates and in the windows updates also but still... -
Realtek(r) Audio Drivers Help
in Windows 10 Ask InsiderRealtek(r) Audio Drivers Help: I recently downloaded Clownfish Voice Changer which made my microphone incredibly quiet and upon researching I found out that I needed to reinstall my Realtek Audio Drivers. I followed a tutorial I found but it didn't work, I just heard a popping noise from my headset and... -
Realtek (R) Audio
in Windows 10 Drivers and HardwareRealtek (R) Audio: Hey guys, so I have a problem with my sound and microphone. Everytime I use my mic my friends can hear my game sound and it's really annoying. (Echo) There's also a missing sound enhancement. Now I can't even hear anything and I don't know how to change Realtek (R) Audio to... -
Realtek(R) Audio?
in Windows 10 Drivers and HardwareRealtek(R) Audio?: Hello, I just purchased a new Laptop(Acer Aspire 3)and I open it and start to intall my usual software, and uninstall crappy programs etc. I would play some music in Aimp4, and then for the first time, I see and listened to Realtek(R) Audio. It only supports 16bit 44khz... -
Muted Audio After Restarting
in Windows 10 Drivers and HardwareMuted Audio After Restarting: Hi, I have a SteelSeries Siberia 650 headset and I'm using their latest drivers/controllers to handle the audio from my computer. The thing is I'm facing a weird problem since then. Everytime I restart my computer (using the 'Shut down' option and turning it back on),...
