Windows 10: Problem with sound and other functions
Discus and support Problem with sound and other functions in Windows 10 Drivers and Hardware to solve the problem; The last update to my computer (Inspiron 17 7000 series) took place several days ago. Since then, I am having a problem. When I start my computer, the... Discussion in 'Windows 10 Drivers and Hardware' started by DeborahD_777, Jan 19, 2019.
Problem with sound and other functions - Similar Threads - Problem sound functions
Time and other functions are not working
in Windows 10 GamingTime and other functions are not working: The time works in my PC if I check on the time and date settings. However when I look at the bottom right hand corner it does not move. I noticed it just today but I dont know when the issue started. Also, other buttons like battery and sound is not clickable as well even... -
in Windows 10 Software and AppsTime and other functions are not working: The time works in my PC if I check on the time and date settings. However when I look at the bottom right hand corner it does not move. I noticed it just today but I dont know when the issue started. Also, other buttons like battery and sound is not clickable as well even... -
in Windows 10 CustomizationTime and other functions are not working: The time works in my PC if I check on the time and date settings. However when I look at the bottom right hand corner it does not move. I noticed it just today but I dont know when the issue started. Also, other buttons like battery and sound is not clickable as well even... -
Sound Problems / Headphones and other audio devices not working
in Windows 10 Software and AppsSound Problems / Headphones and other audio devices not working: Hi thereI've had my PC for around 3-4 years and it has worked completely fine in that time. Only recently, for the past 4 months or so I've only been able to use sound through my monitor as trying to plug in headphones or earphones into both my front USB audio and mic jack... -
microphone catching sound, not functioning in other apps
in Windows 10 Gamingmicrophone catching sound, not functioning in other apps: in settings, i see that the integrated mic i use catches sound as it should, but in every app i want, the sound doesnt register at all. The inputs are correct, mics enabled, reinstalled drivers, still doesnt work, when i try to ."Intel smart sound technology for digital... -
in Windows 10 Software and Appsmicrophone catching sound, not functioning in other apps: in settings, i see that the integrated mic i use catches sound as it should, but in every app i want, the sound doesnt register at all. The inputs are correct, mics enabled, reinstalled drivers, still doesnt work, when i try to ."Intel smart sound technology for digital... -
Microphone for searches and other functions
in CortanaMicrophone for searches and other functions: Hello, I have just received a new laptop and to much of my disappointment it does not come with google installed. To be honest the only reason I even ever considered using Google rather than Bing Microsoft program was because I was in an accident 12 yrs ago and was left... -
No sound with windows 10 media player or any other function on the computer such as...
in Windows 10 BSOD Crashes and DebuggingNo sound with windows 10 media player or any other function on the computer such as...: This problem began during my first attempt to stream a movie from AMC. Other streaming services, I've mostly used Netflix, used to work just fine. Now I can't get sound with anything.... -
A device attached to the system is not functioning Sound problem
in Windows 10 BSOD Crashes and DebuggingA device attached to the system is not functioning Sound problem: I am running Windows 10 upgraded from Windows 7 on an HP PC and when I hover over the speaker icon on the taskbar it says no audio output device is installed. In the Device Manager it shows under Other devices Audio Device on High Definition Audio Bus with an exclamation...
