Windows 10: problem with sound settings not opening
Discus and support problem with sound settings not opening in Windows 10 Customization to solve the problem; i try to open sound settings and then command prompt opens then closes i already scanned for virus which found 17 virus , i used Malwarebytes , i also... Discussion in 'Windows 10 Customization' started by wolf warrior795, Sep 11, 2020.
problem with sound settings not opening - Similar Threads - problem sound settings
windows 10, sound settings problem
in Windows 10 Gamingwindows 10, sound settings problem: I think the image is descriptive enough. it's not showing any input or output devices.But here, I can see all the sound devices. https://answers.microsoft.com/en-us/windows/forum/all/windows-10-sound-settings-problem/57991ba4-0507-4097-b469-2bcac2ba473e -
Cannot open sound settings
in Windows 10 CustomizationCannot open sound settings: I recently had to factory reset my computer, but ever since i reinstalled windows I can no longer open the settings from the taskbar. This is important because I have a goxlr and I no longer access the 'app volume and devices preferences', so I can't assign different apps to... -
No sound unless Sound Settings is open?
in Windows 10 Ask InsiderNo sound unless Sound Settings is open?: Hello, So I have had this problem for like 4 months and now I finally want to fix it. Basically, when windows 10 boots up, my sound works perfect but as soon as a video game, zoom or discord opens up, my sound stops working unless I have the Sound Settings in System... -
No sound from Pc unless sound setting are open.
in Windows 10 Ask InsiderNo sound from Pc unless sound setting are open.: I don't get any sound from my PC unless I open sound settings. I don't know what's going on and it's very frustrating. I would open a game and not sound so I open sound setting and low and behold the sound output device is correct and the sound comes on. I thought okay weird... -
in Windows 10 Customizationsound settings problem: Whenever I go on conference call people don't hear me quite loud and clear. Even I tried with headphone that does the same. Am I missing something? https://answers.microsoft.com/en-us/windows/forum/all/sound-settings-problem/5dbee5fe-bd5e-44ed-965e-45ade11d4645 -
Can not open "taskbar setting" and "open sound setting" from taskbar
in Windows 10 CustomizationCan not open "taskbar setting" and "open sound setting" from taskbar: I have a problem with my windows 10. I Can not open "taskbar setting" and "open sound setting" from the taskbar. when I want to open them a black page appears and closes instantly.... -
Cannot open network and internet settings and sound settings
in Windows 10 Network and SharingCannot open network and internet settings and sound settings: Here is my problem, i cannot open the network and internet settings at the tray but it directs to a command prompt pop up and i dont know why. And i just found out as well in opening sound settings at tray the same issue on popping cmd. I tried to create a new user and this... -
Problem with sound settings
in Windows 10 Ask InsiderProblem with sound settings: [ATTACH] hello! im having an issue where this: The sound settings i want doesn't show up when you press the sound settings on the desktop, so i have to go to control panel<sound settings which is annoying if you need to be quick. cheers in advance! submitted by... -
Sound ICON in Control panel will not open sound settings.
in Windows 10 CustomizationSound ICON in Control panel will not open sound settings.: Control panel will open, but when I click on sound, It errors with [ATTACH] This has been bugging me for awhile now, and I have struggled trying to fix it... I need to boost the mic I use for skype as the volume is too low. Windows 10 64 bit OS Several other Icons in...
