Windows 10: Problem with storagewindows 11 dual botting problem
Discus and support Problem with storagewindows 11 dual botting problem in Windows 10 Software and Apps to solve the problem; My attempt at dual booting Windows 11 and Linux was unsuccessful. Initially, Windows 11 refused to boot up, and even after finally getting Linux to... Discussion in 'Windows 10 Software and Apps' started by ZaidBaida, Mar 29, 2023.
Problem with storagewindows 11 dual botting problem - Similar Threads - Problem storagewindows dual
in Windows 10 GamingProblem with storagewindows 11 dual botting problem: My attempt at dual booting Windows 11 and Linux was unsuccessful. Initially, Windows 11 refused to boot up, and even after finally getting Linux to work, The Linux OS demanded a specific storage capacity, which I fulfilled by installing the OS on 250GB. When I tried testing... -
Dual monitors problem
in Windows 10 Software and AppsDual monitors problem: Hello,I have purchased 2nd monitor for my laptop, running windows 11 pro.When I try to set different wallpaper according to every guide online, it doesn't allow me.Like I am going to Setting -> Personalization -> Background and when I right click on the picture that I want it... -
Dual Boot Problem
in Windows 10 Installation and UpgradeDual Boot Problem: HiI recently installed windows 10 on a second hard disk. And now my old hard disk with windows 8 won't boot... I tried a bit with bcdboot but didn't manage. How can I get it to work?... -
dual monitor problem
in Windows 10 Software and Appsdual monitor problem: Dear Microsoft I recently added a second monitor to my computer on the DVI port with a DVI to VGA adapter. Since then the usb Wifi adapter on the back panel of the motherboard usb, stops working and windows is disconnected from the network. When I disconnect the second screen... -
DUAL Monitor problems
in Windows 10 Graphic CardsDUAL Monitor problems: Hair Tearing Time I am having more issues getting dual displays to function properly on W10. It seems to be two fold. Resolution and PnP detection. Same two monitors on Win 7 machine work just fine. Here is the setup. 4 Desktops.3 run Win7 one runs Win10Startech KVM 4 port... -
Problems with Windows 10 bot home and pro
in Windows 10 BSOD Crashes and DebuggingProblems with Windows 10 bot home and pro: Three time I have been told my pin or password was wrong, and so I was prevented from booting up windows. In each case the pin or password was correct. There was nothing I could do, so had to start a new installation. I have had my activation code rejected when it was valid... -
Dual monitor problem
in Windows 10 Ask InsiderDual monitor problem: Hopefully someone can help me with this, My main monitor is connected to the HDMI (GT 1030) My second monitor is connected to the VGA on my motherboard. Last night I got it to work by going to bios and changing the display to VGA first. So my dual screen was working fine.... -
Dual Booting Problem
in Windows 10 Ask InsiderDual Booting Problem: In my computer I have 2 SSD. 1 is for my personal use. 1 is for work use. The work use one was cloned from my wife's work PC. I would like to be able to choose from either drive upon startup. However, upon installing the work SSD, it appears that it's drive letter is set to... -
in Windows 10 Drivers and Hardwaredual monitor problem: I replaced a smaller monitor with a dell se2417hg monitor to match the first monitor. The computer will not recognize it, it shows up only as generic pnp, and even after going in and updating the driver, it will not give me the resolution option that I need to make the...
