Windows 10: Problem with system tray icons sticking?
Discus and support Problem with system tray icons sticking? in Windows 10 Support to solve the problem; I have several items in my system tray (Windows 10, version 1909). But 3 of these "start with Window's" programs will not load on startup? I have... Discussion in 'Windows 10 Support' started by Willabong, Jan 18, 2020.
Problem with system tray icons sticking? - Similar Threads - Problem system tray
System Tray Icon Will Not Display.
in Windows 10 GamingSystem Tray Icon Will Not Display.: Win 10 x64On my system tray I have several icons for running programs. I know to to set them up to display.One of the programs is running, as confirmed by various methods but refuses to display on the system tray.The icon is activated but it just does not show. As all the... -
Tasbar / System Tray Problem with Icons Aligment
in Windows 10 Software and AppsTasbar / System Tray Problem with Icons Aligment: Hi,I have set my tasbar to show small icons but at this setting the system tray area shows WiFi, Volume Battery and clock misaligned see image below.Is this a bug?Is this adjustable?Do I need to report anywere to have MS fix in future updates?Any help apprecaited.Nick.... -
in Windows 10 GamingTasbar / System Tray Problem with Icons Aligment: Hi,I have set my tasbar to show small icons but at this setting the system tray area shows WiFi, Volume Battery and clock misaligned see image below.Is this a bug?Is this adjustable?Do I need to report anywere to have MS fix in future updates?Any help apprecaited.Nick.... -
System tray icon size
in Windows 10 CustomizationSystem tray icon size: In a recent windows update i noticed that the system tray, little arrow on the bottom right of task bar when opened, the icons have stayed the same size but the buttons to click on them are alot larger. This widens the system tray alot. Is there any way how to change this?... -
Problem in system tray icons!
in Windows 10 CustomizationProblem in system tray icons!: Windows security icon appears on all programs in system tray, and thereal programs icons don't appear. Why? How I can Fix it? System: Windows 10 Pro - 64 bit Version: 2004 [ATTACH] [ATTACH]... -
System Tray Icon
in Windows 10 CustomizationSystem Tray Icon: I have a vision problem and the Safely Remove Icon is very hard for me to see. I would like to change the icon to something more visible. I can't seem to find it in the registry. Thank you.... -
system tray icons
in Windows 10 Customizationsystem tray icons: I received an update to Win 10 and ever since the update, I am only able to see two icons on the system tray at the same time. For example, I now have the speaker icon and the wifi "fan" icon on the system tray. I would like to also have the battery icon on like I've always... -
Taskbar : System tray problem : icon are not all show
in Windows 10 CustomizationTaskbar : System tray problem : icon are not all show: Hi everyone ! First of all, pardon my English, that's not my native language, try' my best here ! I have a problem, and I think a picture will say more than anything else : [ATTACH] Does anyone know how I can reajust this setting ? Searching for a while, impossible to... -
Ugly system tray icons
in Windows 10 CustomizationUgly system tray icons: This is not really a problem, but is there a way to make these icons look better? [img] Especially the Wifi and battery icons. 48490
