Windows 10: Problem with the system tray and slight stuttering of Start Menu
Discus and support Problem with the system tray and slight stuttering of Start Menu in Windows 10 BSOD Crashes and Debugging to solve the problem; Hi everyone, I need some help. So my laptop boots up perfectly fine and the windows 10 apps and the desktop apps also work perfectly. The problem i... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Malay Singh, Mar 30, 2020.
Problem with the system tray and slight stuttering of Start Menu - Similar Threads - Problem system tray
Windows 11 - Slight issue with pinning applications to start menu
in Windows 10 GamingWindows 11 - Slight issue with pinning applications to start menu: When I click pin to start for an application, it seems like nothing happens until I then click unpin from start then click pin to start again. This is not such a big problem, but it is a little annoying and it confuses me.... -
in Windows 10 Software and AppsWindows 11 - Slight issue with pinning applications to start menu: When I click pin to start for an application, it seems like nothing happens until I then click unpin from start then click pin to start again. This is not such a big problem, but it is a little annoying and it confuses me.... -
System tray popup menu not working
in Windows 10 GamingSystem tray popup menu not working: Hello there,I installed Windows 11 through the Insider about two weeks before it was released. Since then, I'm having this issue, where the popup menu that comes when you click on the WiFi / Battery / Volume icon in the system tray is missing. The icons are there, and when I... -
in Windows 10 Software and AppsSystem tray popup menu not working: Hello there,I installed Windows 11 through the Insider about two weeks before it was released. Since then, I'm having this issue, where the popup menu that comes when you click on the WiFi / Battery / Volume icon in the system tray is missing. The icons are there, and when I... -
Problem in system tray icons!
in Windows 10 CustomizationProblem in system tray icons!: Windows security icon appears on all programs in system tray, and thereal programs icons don't appear. Why? How I can Fix it? System: Windows 10 Pro - 64 bit Version: 2004 [ATTACH] [ATTACH]... -
Getting CoreTemp to start in system tray
in Windows 10 Software and AppsGetting CoreTemp to start in system tray: I'm having a weird issue with CoreTemp at startup on my new Windows 10 64-bit PC. I'm using it to display the temp and CPU load in my system tray. I have it set to run at startup, and I have "start Core Temp minimized" selected. Yet during system startup the CoreTemp Window... -
Start Outlook to system tray at logon
in Microsoft Office and 365Start Outlook to system tray at logon: Hello to everybody, What I would like to do is to start Outlook 2016 at logon minimized to the notification area (system tray) ONLY. I have tried it in 3 different ways: 1. Created a task to run after 1 minute from logon. <Command>"C:\Program Files\Microsoft... -
Start Menu Slight Issue
in Windows 10 SupportStart Menu Slight Issue: Has anyone else had an issue with start menu where you search for a particular program that runs when you click it but the sidebar of the start menu stays open? It doesn't do it all the time but its a bit of a bug bare really. I've had a look online and similar issues seem to... -
common problem - start menu, taskbar, system tray etc not working
in Windows 10 Supportcommon problem - start menu, taskbar, system tray etc not working: Hello, I know its a common problem with 10 but here is a list of my problems that occurred a few days after upgrading to windows 10. start menu isn't accessible (unless i download classic shell) task bar isn't accessible system tray isn't accessible - i can't even...
