Windows 10: Problems while recording audio using Win 10 in built microphone.
Discus and support Problems while recording audio using Win 10 in built microphone. in Windows 10 Ask Insider to solve the problem; I have been trying to record audio through the inbuilt microphone for a video. However, the recorded audio volume decreases and come back to normal... Discussion in 'Windows 10 Ask Insider' started by /u/saterd57, Jul 10, 2020.
  1. Problems while recording audio using Win 10 in built microphone.
    I have been trying to record audio through the inbuilt microphone for a video. However, the recorded audio volume decreases and come back to normal after every intervals. I have realtek audio installed. Using audacity and obs studio, both have the same problem with the audio. Any help would be greatly appreciated.
    submitted by /u/saterd57
    [link] [comments]
  2. Arun B J Win User
    Built in microphone not working
    I understand your concern and will assist you to resolve this issue.
    I suggest you to follow the steps below and check if it helps
    Method 1: I suggest you to set microphone as default device and check.
    • Right click on the volume icon in the system tray and then click "Recording devices"
    • Right click on the blank space in the popped up window and then select "Show Disabled Devices" and "Show Disconnected Devices".
    • Right click on Microphone and then click "Enable".
    • Highlight the microphone and then choose "Set as Default Device".
    • Click Apply and OK.
    Step 2: Make sure that the Microphone is not disabled.
    • Make sure that the Microphone is not disabled. Follow the steps given to check that:
    • Right click on the volume icon and select “Recording devices”.
    • Now, Right Click on an empty space and select, “Show disconnected devices” and “Show disabled devices”.
    And also update the audio drivers from the manufacturer web site and install.
    Hope this helps. If the issue remains unresolved, please get back to us and we would be happy to help
    Arun B J, Jul 10, 2020
  3. Ryan Fra Win User
    Can not record audio.
    We suggest that you run troubleshooting for Audio Recording by following these steps:
    • Type troubleshooting on the search box.
    • Click View all.
    • Select Recording Audio.
    • Follow the steps to troubleshoot Recording Audio.
    Let us know if you need further help.
    Ryan Fra, Jul 10, 2020
  4. Problems while recording audio using Win 10 in built microphone.
    Photos app not working when trying to start using a microphone
    Hi Kad,
    Welcome to Microsoft Community and we appreciate your interest in Windows 10.
    I will definitely assist you.
    It would be grateful if you could provide us few questions answer to understand the issue better and to provide you better assistance.
    • Are you using microphone headset or in-built microphone which came with the computer?
    Let’s try simple steps and check if this help in resolving the issue. Follow the below steps.
    Step 1.
    I would suggest you to run Recording audio troubleshooter and check if it helps.
    • Type troubleshoot on the Window search bar and select
      troubleshooting.
    • Click on view all and click on
      Recording Audio.
    • Click on Advanced on the Recording Audio troubleshooter dialog box and click on Run as administrator (Enter the credentials if required).
    • Click on Next and follow onscreen instruction complete the Recording Audio troubleshooter.
    If the issue still persist, try the below step:
    Step 2.
    I would suggest you to update the sound driver from Device Manager manually and check if this helps. Follow the below steps:
    • Press (Windows key + X) and click on “Device Manager”.
    • Expand “Audio inputs and outputs”.
    • Right click on the audio driver device and select
      update.
    • Once update is done, restart the computer.
    Hope this helps. Post us with the status we will be glad to help you.
    Billion Debbarma, Jul 10, 2020
  1. Problems while recording audio using Win 10 in built microphone. - Similar Threads - Problems while recording
  2. Built in screen recorder audio not working
    Built in screen recorder audio not working: I'm trying to screen record a presentation on Google Slides using the built-in screen recorder but it's not recording the audio. It's completely mute....
  3. Audio recording problem
    Audio recording problem: I'm sure this has been discussed before but... I have more than 40 years of working on and with computers so I've already tried the common solutions to this. I have a Windows 10 computer which updates automatically when MicroSoft sends out an update. I'm digitizing my...
  4. Plug in Microphone not recording audio?
    Plug in Microphone not recording audio?: i have a Microphone, it has a converter that puts it into a 3.5 mm two prong audio cable. When i plug it into my computer it wont record and is acting as the left audio channel, is there a way to fix this? maybe change the settings?...
  5. Problem using the built-in screen recorder.
    Problem using the built-in screen recorder.: Hey all, I've been using the built-in screen recorder (WINKEY+Alt+R) to capture footage for a school project. However, half the time, there is no audio in the clip. This forces me to recapture the footage with the hope that the audio will work that time. Y'all got any fix for...
  6. Problems recording audio with the built-in screen recorder.
    Problems recording audio with the built-in screen recorder.: Hey all, I've been using the built-in screen recorder (WINKEY+Alt+R) to capture footage for a project. However, half the time, there is no audio in the clip. This forces me to recapture the footage with the hope that the audio will work that time. Y'all got any fix for this?...
  7. In built screen recorder not recording audio
    In built screen recorder not recording audio: The in built screen recorder is not recording audio, however when i have my earphones in i can hear some audio however it is really glitchy and broken, without my earphones in there is not sound at all. I have troubleshooted the audio recording but there were no problems...
  8. Win 10 built in screen recorder.
    Win 10 built in screen recorder.: If I am recording a game and switch over to discord will the record stop automatically? If so, how can I prevent it? submitted by /u/padster029 [link] [comments] https://www.reddit.com/r/Windows10/comments/e04s5i/win_10_built_in_screen_recorder/
  9. Recording audio problem
    Recording audio problem: I'm trying to record audio from a browser using Audacity. It will record audio using a microphone but not using the "line inputs" i.e. realtek. I enabled the Stereo mix Realtek device, restarted and it still won't recognize the browser as the input to audacity. Then I ran...
  10. Problem with recording microphone
    Problem with recording microphone: My PC is using internal microphone for recording purposes and not the microphone on headphones. Headphones are working fine and checked it on another PC. I've also tried setting up the microphone. I also reinstalled the audio driver. I got to know this after listening to the...
