Windows 10: Problems with Battery
Discus and support Problems with Battery in Windows 10 Software and Apps to solve the problem; I've been having many problems with my batteries over the last couple of months. When fully charged the battery would go nowhere over 79%. When it... Discussion in 'Windows 10 Software and Apps' started by OskarBarron, Feb 3, 2022.
Problems with Battery - Similar Threads - Problems Battery
Same problem as in 2022, log in W11 after battery replaced. What do I do?
in Windows 10 GamingSame problem as in 2022, log in W11 after battery replaced. What do I do?: Windows 11 laptop used to log in with password. Then after battery was replaced, unable to sign in with password. error message "This sign in option is disabled because of failed sign in attempts or repeated shutdowns. Use a different sign-in option or keep your device... -
in Windows 10 Software and AppsSame problem as in 2022, log in W11 after battery replaced. What do I do?: Windows 11 laptop used to log in with password. Then after battery was replaced, unable to sign in with password. error message "This sign in option is disabled because of failed sign in attempts or repeated shutdowns. Use a different sign-in option or keep your device... -
I have a problem that windows default lockscreen draining my battery overnight
in Windows 10 GamingI have a problem that windows default lockscreen draining my battery overnight: I have fully charged the laptop, leave it in sleeping mode and in the morning it was empty. I have checked the report within 24 hours for the battery. It was shown that windows default lock screen consumes more than 70% of the battery?... -
in Windows 10 Software and AppsI have a problem that windows default lockscreen draining my battery overnight: I have fully charged the laptop, leave it in sleeping mode and in the morning it was empty. I have checked the report within 24 hours for the battery. It was shown that windows default lock screen consumes more than 70% of the battery?... -
Battery problems after having dropped laptop?
in Windows 10 GamingBattery problems after having dropped laptop?: Hello! Two days ago, I dropped my laptop MSI gaming laptop, Windows 11 Home. Nothing seems to be wrong despite some cracks on the very right edge of the laptop which I don't think are concerning, as there's nothing wrong with the screen I dropped it while it was off and the... -
in Windows 10 Software and AppsBattery problems after having dropped laptop?: Hello! Two days ago, I dropped my laptop MSI gaming laptop, Windows 11 Home. Nothing seems to be wrong despite some cracks on the very right edge of the laptop which I don't think are concerning, as there's nothing wrong with the screen I dropped it while it was off and the... -
Battery problem
in Windows 10 GamingBattery problem: After I downloaded Windows 11 version 24H2, I noticed strange problems with the battery icon. For example I charge my pc and it's 99% battery, Despite I use it several hours the battery icon ramains the same even after I used it!! It's still 99% and it's insane! How is it... -
Battery problem
in Windows 10 Software and AppsBattery problem: After I downloaded Windows 11 version 24H2, I noticed strange problems with the battery icon. For example I charge my pc and it's 99% battery, Despite I use it several hours the battery icon ramains the same even after I used it!! It's still 99% and it's insane! How is it... -
Barely used gaming laptop, updated windows, and have battery problems help?
in Windows 10 Software and AppsBarely used gaming laptop, updated windows, and have battery problems help?: Barely used gaming laptop, updated to the newest microsoft updates and all the sudden when playing games or what not it kicks me off using plugged in should I roll back is the update what has caused this?...
