Windows 10: problems with bluetooth and device connectivity
Discus and support problems with bluetooth and device connectivity in Windows 10 Drivers and Hardware to solve the problem; dear community, i have just upgraded my laptop from windows 8 to windows 10 and the bluetooth was working just fine. after a while suddenly it stopped... Discussion in 'Windows 10 Drivers and Hardware' started by MohitHiray, Sep 27, 2019.
problems with bluetooth and device connectivity - Similar Threads - problems bluetooth device
Problems with bluetooth connection after removing a device.
in Windows 10 GamingProblems with bluetooth connection after removing a device.: Hey,I was having some issues with a Yamaha src20a soundbar which was connected via Bluetooth to my windows 11 PC. I tried turning off/on my Bluetooth etc but didn't fix the issue, so I forgot the device from my Bluetooth connections on my PC. When I tried to repair the device... -
in Windows 10 Software and AppsProblems with bluetooth connection after removing a device.: Hey,I was having some issues with a Yamaha src20a soundbar which was connected via Bluetooth to my windows 11 PC. I tried turning off/on my Bluetooth etc but didn't fix the issue, so I forgot the device from my Bluetooth connections on my PC. When I tried to repair the device... -
Problem with connecting Bluetooth device
in Windows 10 GamingProblem with connecting Bluetooth device: I have a Lenovo Laptop AMD ryzen 3 and integrated graphics, that too AMD and for the past few months, whenever I try to connect my Bluetooth earphones, they just start glitching and disconnect and reconnect very fast the device connects and reconnects probably 4-5 times per... -
in Windows 10 Software and AppsProblem with connecting Bluetooth device: I have a Lenovo Laptop AMD ryzen 3 and integrated graphics, that too AMD and for the past few months, whenever I try to connect my Bluetooth earphones, they just start glitching and disconnect and reconnect very fast the device connects and reconnects probably 4-5 times per... -
Bluetooth devices not connecting.
in Windows 10 Software and AppsBluetooth devices not connecting.: Hi, when I try to pair bluetooth devices to my pc, it pops up in the devices screen where I can select what device to use. But when I try to connect it, all it does is load for very long and afterwards I get a message with: Try to connect the device again. I am in range of... -
Bluetooth Device not connecting.
in Windows 10 GamingBluetooth Device not connecting.: I performed a reset through cloud download of my HP Pavilion 15-dk0050tx Windows 10 Laptop from windows' settings app.After the reset, I observed that my laptop is unable to connect to my mobile through Bluetooth.So I tried a few things from "answers.microsoft.com".What I... -
Bluetooth connection problems with all audio devices
in Windows 10 GamingBluetooth connection problems with all audio devices: Hi! I'm getting this message when I try to connect to my Bluetooth audio devices: "That didn't work. Make sure your Bluetooth device is still visible, then try again", the weird thing is that I get this problem only with audio devices, the ones that I have used in the past... -
in Windows 10 Software and AppsBluetooth connection problems with all audio devices: Hi! I'm getting this message when I try to connect to my Bluetooth audio devices: "That didn't work. Make sure your Bluetooth device is still visible, then try again", the weird thing is that I get this problem only with audio devices, the ones that I have used in the past... -
in Windows 10 Drivers and HardwareBluetooth connection problems with all audio devices: Hi! I'm getting this message when I try to connect to my Bluetooth audio devices: "That didn't work. Make sure your Bluetooth device is still visible, then try again", the weird thing is that I get this problem only with audio devices, the ones that I have used in the past...
