Windows 10: Problems with Charging and Settings
Discus and support Problems with Charging and Settings in Windows 10 BSOD Crashes and Debugging to solve the problem; I've had my PC for about 2 years now, and this problem started occurring in about 2018 April. Battery/Charger Issues: If I plug in my charger to my... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by -Bee, Jul 17, 2019.
Problems with Charging and Settings - Similar Threads - Problems Charging Settings
Charging Problem
in Windows 10 GamingCharging Problem: HelloI have a strange problem with my Acer Nitro 5 AN515-44. My laptop's battery is in good situation and keeps charge for more than 6 hours. But a strange things are happening. sometimes when it gets fully charge up to 100%, it suddenly turns off. then I turn it on again,... -
Charging Problem
in Windows 10 Drivers and HardwareCharging Problem: HelloI have a strange problem with my Acer Nitro 5 AN515-44. My laptop's battery is in good situation and keeps charge for more than 6 hours. But a strange things are happening. sometimes when it gets fully charge up to 100%, it suddenly turns off. then I turn it on again,... -
Charging problem
in Windows 10 Drivers and HardwareCharging problem: My laptop turns on and works, but it won't charge. I plug in the laptop, and the charging indicator light won't light up, and Windows says it's not charging. Usually when the charger won't work i can tilt around the charger to make it work, but it won't work now. Help!... -
Charging problem
in Windows 10 GamingCharging problem: My laptop turns on and works, but it won't charge. I plug in the laptop, and the charging indicator light won't light up, and Windows says it's not charging. Usually when the charger won't work i can tilt around the charger to make it work, but it won't work now. Help!... -
charging problem
in Windows 10 Performance & Maintenancecharging problem: my battery is not charging after reaching 60% if I charge full night https://answers.microsoft.com/en-us/windows/forum/all/charging-problem/48237b94-79dd-4a1b-8799-5fc7d94b6620 -
Charging problem
in Windows 10 Drivers and HardwareCharging problem: Hey guys! I need everyone's help. I have an Acer laptop that sometimes freezes when I plug in the power pack. Anyone with a permanent solution to this problem? The temporal solution is unplugging the laptop. Thanks.... -
Charging Problems
in Windows 10 BSOD Crashes and DebuggingCharging Problems: When charging my HP Stream laptop it heats up and will completely lock it self up while making this loud buzzing noise and the only way to get it to stop is to shutdown my laptop and reboot any fixes? sidenote I got a bluescreen when this happened and the stop code was as... -
problems charging
in Windows 10 Drivers and Hardwareproblems charging: My laptop is a Dell and I have had about a year or so but bought it in good condition/lightly used from a store, never had issues. I have had my laptop plugged in, it says it is plugged in but that it is not charging. The only thing I have used in the past 2 days is run... -
Charging Problem
in Windows 10 SupportCharging Problem: Hello Everyone, I have this charging problem that just started yesterday. My laptop, an ASUS UX51VZ, would only charge when powered off. When on, the power dialog from the taskbar when brought up would say something like "calculating," the charging light on the side of the...
