Windows 10: Problems with connecting an external monitor to a laptop with hdmi to vga adapter
Discus and support Problems with connecting an external monitor to a laptop with hdmi to vga adapter in Windows 10 Graphic Cards to solve the problem; I am having a problems with connecting an external monitor to a laptop with a hdmi to vga adapter/converter, the weird thing is that the monitor works... Discussion in 'Windows 10 Graphic Cards' started by markonjak, Jul 20, 2019.
Problems with connecting an external monitor to a laptop with hdmi to vga adapter - Similar Threads - Problems connecting external
VGA to hdmi adapter
in Windows 10 GamingVGA to hdmi adapter: just purchased a computer with Windows 11. I want to connect a monitor with a VGA male connection. I bought a n Insignia vga to hdmi adapter and connected it through HDMI. However, the monitor has a floating bubble that says "no vga cable”. What’s going on? How do I make this... -
VGA to hdmi adapter
in Windows 10 Software and AppsVGA to hdmi adapter: just purchased a computer with Windows 11. I want to connect a monitor with a VGA male connection. I bought a n Insignia vga to hdmi adapter and connected it through HDMI. However, the monitor has a floating bubble that says "no vga cable”. What’s going on? How do I make this... -
Problem with laptop HDMI port and Epson VGA projector connectivity
in Windows 10 GamingProblem with laptop HDMI port and Epson VGA projector connectivity: I have a Lenovo IdeaPad S145 laptop with a HDMI port. When I try to connect an Epson projector e.g. EB-X9 with VGA input with a HDMI-VGA adaptor, the projector screen says "Not supported" and my laptop display goes on and off with an alarm sound. I have already tried changing... -
in Windows 10 Software and AppsProblem with laptop HDMI port and Epson VGA projector connectivity: I have a Lenovo IdeaPad S145 laptop with a HDMI port. When I try to connect an Epson projector e.g. EB-X9 with VGA input with a HDMI-VGA adaptor, the projector screen says "Not supported" and my laptop display goes on and off with an alarm sound. I have already tried changing... -
MacBook Pro Screen Flickering when using HDMI to VGA adapter to connect to external monitor
in Windows 10 Software and AppsMacBook Pro Screen Flickering when using HDMI to VGA adapter to connect to external monitor: My MacBook Pro 2014 keeps flickering when I plug in an HDMI to VGA converter to it. I am using HDMI to plug in the HDMI to VGA converter which is plugged into my monitor. The screen is just black and then the Mac starts flashing. The external monitor does not have any effect.... -
in Windows 10 GamingMacBook Pro Screen Flickering when using HDMI to VGA adapter to connect to external monitor: My MacBook Pro 2014 keeps flickering when I plug in an HDMI to VGA converter to it. I am using HDMI to plug in the HDMI to VGA converter which is plugged into my monitor. The screen is just black and then the Mac starts flashing. The external monitor does not have any effect.... -
in Windows 10 Drivers and HardwareMacBook Pro Screen Flickering when using HDMI to VGA adapter to connect to external monitor: My MacBook Pro 2014 keeps flickering when I plug in an HDMI to VGA converter to it. I am using HDMI to plug in the HDMI to VGA converter which is plugged into my monitor. The screen is just black and then the Mac starts flashing. The external monitor does not have any effect.... -
HDMI to VGA adapter
in Windows 10 Graphic CardsHDMI to VGA adapter: I use the HDMI to VGA adapter to connect one of the old monitor as second monitor on my system. It works great. But, twice now, the adapter seemed to stop working after I unplug the monitor from the adapter when it is still hot. Does it make sense that the adapter would burn... -
Cannot connect external screen VGA to HDMI
in Windows 10 Drivers and HardwareCannot connect external screen VGA to HDMI: Hi I am trying to connect an older VGA screen to my fairly new laptop without success. the laptop runs on Windows 10 I have spent ages trying to find a solution here in Support but nothing has worked Things I have tried Update drivers = the drivers are all...
no hdmi signal on dell monitor connecting to xps
,edge closes when connecting hdmi
,HP G5 laptop the machine blue screens when connection HDMI cable to TV
