Windows 10: Realtek Audio HD - Speaker sound also going through mic input
Discus and support Realtek Audio HD - Speaker sound also going through mic input in Windows 10 Customization to solve the problem; I have been using Discord for about a month with no issues but all of a sudden I updated a Realtek Driver and now I have had the Realtek Audio Manager... Discussion in 'Windows 10 Customization' started by The Garbage M4n, Aug 17, 2019.
  1. Realtek Audio HD - Speaker sound also going through mic input
    I have been using Discord for about a month with no issues but all of a sudden I updated a Realtek Driver and now I have had the Realtek Audio Manager popping up whenever I plug my headphone and mic splitter in my 3.5 ports in the motherboard.
    Recently though, my friends on Discord have noticed what I thought was bleed from my headphones from what i was listening to on my computer, but I don't think it is bleed but rather that any sound coming through my speaker output, managed through Realtek, also comes out of my microphone as well.
    I have tried several things listed on the internet and messing with properties but have had no luck. I would appreciate any help to keep my sound output and my mic input separated.
  2. Junaid_A Win User
    Muted mic picking up sound in game
    Hi JonPaul,
    The issue could be because of the internal mic picking up sound even when the external device is pluuged in. If you have the RealTek HD Audi Manager installed on the machine, I would suggest you to try the steps listed below and check if it works for
    you.
    • Open RealTek HD Audio Manager and go to the
      Advanced tab.
    • Check the boxes Separate all input jacks as independent input devices
      and Mute the internal output device, when external headphone is plugged in,
      and hit OK.
    • Exit RealTek HD Audio Manager, restart the machine and see if the issue persists.
    Junaid_A, Aug 17, 2019
  3. Bigjay832 Win User
    I been having trouble with the volume in the mic settings. I tried all I know please help.
    This is the three devices that are under the "Sounds, video, and game controllers" tab:
    • AMD High Definition Audio Device
    • CyberLink Webcam Virtual Drivers
    • Realtek High Definition Audio
    Under the "Audio input and output" tab:
    • Mic in at front panel (black) (Realtek High Definition Audio)
    • Microphone (Realtek High Definition Audio)
    • Realtek HD Output 2nd output (Realtek High Definition Audio)
    • Speaker/HD (Realtek High Definition Audio)
    I use microphone headset to talk to people while playing an online game. The program I use is "Ventrilo". I tried the steps you posted and the mic volume is still muting automatically.
    Bigjay832, Aug 17, 2019
  4. BossDweeb Win User
    Realtek HD audio speakers "Not plugged in"
    If your case has two front panel audio connection options, did you use the
    HD audio
    motherboard connector ?
    AC97 is 'legacy' and may not work on some current motherboards.
    ( There may also be an option to switch between HD and AC97 in the Realtek audio manager, or BIOS
    when using an HD audio connector. If your Realtek audio manager has this option, play around with
    this for different results with the other settings that control front and back panels )
    - Do either speaker or headphone show in Device Manager, Control Panel > Sound,
    and the Realtek audio manager ?
    'I have like 2 headphones plugged in and two front speakers '
    - Start out with either speakers, or a headphone until you get the audio going.
    Use the rear outputs for the speakers, and front for headphones.
    I would be inclined to try and get the rear speaker output going first because it is connected
    directly to the motherboard.
    BossDweeb, Aug 17, 2019
  1. Realtek Audio HD - Speaker sound also going through mic input - Similar Threads - Realtek Audio Speaker
  2. PC audio is going through mic input
    PC audio is going through mic input: When I am on a voice chat with someone, they can hear themselves. Whenever I play sound through my Windows 11 PC, they are able to hear it. This makes VC's really tough. I don't know what the issue is, whether it is with my mic or with my pc. It worked up until recently. I...
  3. PC audio is going through mic input
  4. Realtek HD speakers make no sound
    Realtek HD speakers make no sound: I have an ASUS desktop PC with Windows 10. My Realtek speakers have been working very well. One day they did not work. I'm not aware of any changes I may have made in settings. I have not been able to get them to come back on line. I downloaded the latest driver and it still...
  5. Input (mic) Stereo Mix (realtek) not picking up sound through Mic
    Input (mic) Stereo Mix (realtek) not picking up sound through Mic: Acer Predator PH315-52 Windows 10 Home 1909 When I have my sound input set to Stereo Mix (realtek) i can pickup and record or broadcast anything playing internally like youtube or my music files however the external mic wont pick up any sound externally like my voice. Then...
  6. Realtek HD audio speakers "Not plugged in"
    Realtek HD audio speakers "Not plugged in": please help me[ATTACH] https://answers.microsoft.com/en-us/windows/forum/all/realtek-hd-audio-not-plugged-in/2641c392-3b1c-46c8-b52e-e04b050c3430
  7. Headphone mic not detected by realtek HD audio
    Headphone mic not detected by realtek HD audio: Okay, so I've been working on this for roughly two hours, searching google as well as looking through the various settings, and I can't seem to find the problem. A few weeks ago, everything worked perfectly, clean and crisp sounds, the works. But today I decided to login and...
  8. Realtek audio mic outputting to speakers/headphones
    Realtek audio mic outputting to speakers/headphones: well i had this problem fixed but for some reason it's back and it won't go away no matter what i do i can't figure out how to fix it I can hear my microphone through my headphones and speakers i have listen to device unchecked but the weird part is when i try to record my...
  9. Realtek HD Audio Driver and Internal Mic Problem
    Realtek HD Audio Driver and Internal Mic Problem: Hi guys, I have some issue with my internal mic. I've updated to the latest Realtek HD Audio Driver from this forum, I then used windows "Voice Recorder" program to record my voice to see if the mic was working, but it did not register a single word i said. I then...
  10. Realtek HD audio indentifies headphones as speakers.
    Realtek HD audio indentifies headphones as speakers.: Realtek HD Changing Jack output reassignments ( FIX ) - Windows 7 Help Forums I found this old thread but I couldn't get any help from it because my regedit index doesn't look the same as theirs. I don't have a "DevType_0888_SS147b1083" or "DevType_0885_SS18490890"...
  1. laptop speker sound going troug mic
