Windows 10: Realtek Audio not working and is causing me lots of problems
Discus and support Realtek Audio not working and is causing me lots of problems in Windows 10 Software and Apps to solve the problem; Hi there! My audio was working fine until I decided to update the audio driver. The audio just stopped working, I researched the whole internet, tried... Discussion in 'Windows 10 Software and Apps' started by AarushDhamija, Jan 9, 2022.
Realtek Audio not working and is causing me lots of problems - Similar Threads - Realtek Audio working
Realtek audio problem
in Windows 10 Software and AppsRealtek audio problem: Hello! After updating my AMD drivers and updating windows windows 10, I started having problems with the audio. First, sometimes when I was using the PC, while hearing something, the audio heard kinda of blown out, and to fix it I had to restart the computer, but when I used... -
in Windows 10 BSOD Crashes and DebuggingRealtek audio problem: Hello! After updating my AMD drivers and updating windows windows 10, I started having problems with the audio. First, sometimes when I was using the PC, while hearing something, the audio heard kinda of blown out, and to fix it I had to restart the computer, but when I used... -
in Windows 10 GamingRealtek Audio not working and is causing me lots of problems: Hi there! My audio was working fine until I decided to update the audio driver. The audio just stopped working, I researched the whole internet, tried everything I could find. Nothing worked. The only thing that temporarily fixes it, is uninstalling the driver. After... -
Realtek audio Problems
in Windows 10 Drivers and HardwareRealtek audio Problems: I've been having problems with my audio since I've gotten my pc. If a loudish sound is played it will lower the volume, and slowly increase it to about 400%, and go back to normal. I use Realtek audio drivers, which came with my motherboard. I have spent more than 15 hours... -
No Audio & Realtek Problems
in Windows 10 Ask InsiderNo Audio & Realtek Problems: Booted up my laptop today and there was no audio. Running the troubleshooter in Sound Settings tells me “Audio Services are not responding”. This seems to be an issue with my Realtek drivers. Going into device manager and switching out the Realtek driver for the Default... -
Hibernation causing a lot of problems
in Windows 10 Performance & MaintenanceHibernation causing a lot of problems: I found this in this forum: Created on March 16, 2016 My computer won't wake up from hibernation in Windows 10 My computer recently stopped emerging from hibernation for no apparent reason and forced me to do hard reboots before functioning. I went to Device Manager as you... -
RealTek Audio causing issues, no audio
in Windows 10 Drivers and HardwareRealTek Audio causing issues, no audio: Something happened about 2-3 weeks ago where my audio stopped working. Here's how I fix it but it's just a temporary fix: Device Manager > Sound, Video and Game Controllers > RealTek Audio > [toolbar] Uninstall Device > [popup] Delete the driver software for this device >... -
RealTek audio problems
in Windows 10 Drivers and HardwareRealTek audio problems: No audio, microphone doesn't work. Have troubleshooted, reinstalled audio software, watched many YouTube videos, researched online. The only thing that worked was system recovering my PC and after about 3 days I had to do it again. Then 3 days later I had to system recover... -
Realtek Audio Problems
in Windows 10 Network and SharingRealtek Audio Problems: So at this moment, my speakers are not playing any sound I have a laptop: g703 I've tried reinstalling drivers and even got to the point to download DriverEasy which doesn't happen that often. My troubleshooter picks up the sound but my speaker doesn't play it, I'm starting...
