Windows 10: red cross on sound icon in System tray
Discus and support red cross on sound icon in System tray in Windows 10 Drivers and Hardware to solve the problem; Speakers work & microphone works too. But there is a red cross on the speaker icon in the system tray. Hover over the Icon and pop up says "No speakers... Discussion in 'Windows 10 Drivers and Hardware' started by Clive Bagshaw, May 8, 2021.
red cross on sound icon in System tray - Similar Threads - red cross sound
My Sound Icon shows a red cross ... but sound still works
in Windows 10 GamingMy Sound Icon shows a red cross ... but sound still works: My Sound Icon shows a red cross ... but sound still works. I have a Philips PHL 23V7 monitor connected to my W10 Pro PC via the HDMI. I have a pair of speakers connected directly to the monitor.The behaviou of the ICON has changed. Previously I could immediately change the... -
in Windows 10 Software and AppsMy Sound Icon shows a red cross ... but sound still works: My Sound Icon shows a red cross ... but sound still works. I have a Philips PHL 23V7 monitor connected to my W10 Pro PC via the HDMI. I have a pair of speakers connected directly to the monitor.The behaviou of the ICON has changed. Previously I could immediately change the... -
in Windows 10 Drivers and HardwareMy Sound Icon shows a red cross ... but sound still works: My Sound Icon shows a red cross ... but sound still works. I have a Philips PHL 23V7 monitor connected to my W10 Pro PC via the HDMI. I have a pair of speakers connected directly to the monitor.The behaviou of the ICON has changed. Previously I could immediately change the... -
no sound red cross by speaker icon
in Windows 10 Drivers and Hardwareno sound red cross by speaker icon: I have no sound, getting no output devices connected. I have tried all trouble shootin tips nothing works. I have same problem on windows 7 pc. They both failed at the same time... -
Windows blinks with Red icons in the system tray
in Windows 10 BSOD Crashes and DebuggingWindows blinks with Red icons in the system tray: Dear community, My Laptop with Windows 10 keeps blinking. this is not simply mouse blinking as the system takes you off and brings you back after seconds. Also red icon starts appearing in the system tray and keeps multiplying within Hours. as you hover over them, they... -
No sound and a red cross against the sound icon. Windows 10.
in Windows 10 Drivers and HardwareNo sound and a red cross against the sound icon. Windows 10.: I have a 'no audio driver installed' message after a reset in windows 10. Lots of websites offering audio drivers, that I am unwilling to trust. So Is there away of getting audio drivers from MS, and is Driver Talent a reliable download to overcome my problem? Many... -
Red cross on Internet Icon on Taskbar
in Windows 10 Updates and ActivationRed cross on Internet Icon on Taskbar: After carrying out an upgrade including a new Motherboard, processor and Ram memory I had to re-install Windows Win 10 Pro ( Free upgrade - digital licence type ) unfortunately after I installed it a message appeared a few days later that it needs activating. Following the... -
No sound with red cross over volume tab
in Windows 10 Drivers and HardwareNo sound with red cross over volume tab: Hi there I have this no sound problems on my windows 10 Lenovo Miix 310 netbook. I have had the computer tested for hardware failures, had windows os reinstalled with all the drivers updated, tried different drivers, just about everything under the sun you can think of... -
Red cross on sound
in Windows 10 Drivers and HardwareRed cross on sound: Hello, I have a fresh install on my PC and for some reason it doesn't detect my headphones, I've plugged them in the front and rear and still no luck, all drivers and software are up to date, any idea what's happening? They did use to work before the fresh install. 43067
