Windows 10: Reset PC does not work to address 0xc000021a blue screen problem
Discus and support Reset PC does not work to address 0xc000021a blue screen problem in Windows 10 Gaming to solve the problem; I have today had a problem with my PC whereby I get the blue screen with error message 0xc000021a. I have tried repairs, not working, just loops back... Discussion in 'Windows 10 Gaming' started by HelenAtkins1, Dec 2, 2022.
  1. Reset PC does not work to address 0xc000021a blue screen problem
    I have today had a problem with my PC whereby I get the blue screen with error message 0xc000021a. I have tried repairs, not working, just loops back to same screens. So I tried reset the PC to reinstall windows. Doesn't seem to do anything, I just end up back on same blue screens after the PC attempts to start up and repair. I dont have DVDs/USB for reinstalling Windows, won't load from Cloud. Can't get past any blue screen at all. Any ideas?
  2. RH618 Win User
    Blue screen 0xc000021a on installation of Windows 10
    Having trouble installing Win 10 from a usb stick. I've attached some pics of the boot process and my bios. It happened after trying to "reset" from Windows 10. I have reset the bios on the board with the jumpers. Deleted all partitions on drive and tried it both as having a C:\ drive already registered and not. Any help would be greatly appreciated. Currently booting from a Hiren's USB so have a few options. Never used it before but was useful for formatting the HDD etc.
    I would think it was a hardware problem if it wasn't for it being fine before this. Must be drivers or bios settings?
    Reset PC does not work to address 0xc000021a blue screen problem [​IMG]
    - - - Updated - - -
    After choosing 64bit and it thinking for a second I get the blue screen
    - - - Updated - - -
    - - - Updated - - -
    RH618, Dec 2, 2022
  3. Fix error 0xc000021a Windows 10
    I've faced this issue before. It's one of the blue screen of death errors. Im sharing 5 steps that will help you fix Error 0xc000021a
    One of the following step will sort out the problem:
    1. Repair corrupted system
    2. Boot window manually
    3. Resetting computer's BIOS
    4. DO SFC scan
    5. Troubleshoot to fix automatically
    Clout Techie, Dec 2, 2022
  4. Arul_D Win User
    Error code 0xc000021a win 10 blue screen
    Hi Michael,
    • When exactly you are getting this error message?
    • What is the exact error message or error code you are getting?
    Before we proceed, I would like to know which steps have you tries to fix the issue.
    For now, I suggest that you refer to the post by ZigZag3143 and by Vinodh_Kumar in the respective post below and check if it rectifies your issue
    Link 1: ZigZag3143
    Redirecting
    Link 2: Vinodh_Kumar
    Redirecting
    For more info about the error, you ca click on the link below
    https://msdn.microsoft.com/en-us/library/windows/hardware/ff560177(v=vs.85).aspx
    Hope this helps.
    Arul_D, Dec 2, 2022
  1. Reset PC does not work to address 0xc000021a blue screen problem - Similar Threads - Reset does address
  2. Blue screen 0xc000021A
    Blue screen 0xc000021A: Hey i have been getting a blue screen for 3 days straight now with the code 0xc000021A and i cant get through with my windows password because i forgot it and the forgot it option also doesnt work because that resets it and throws it in a loop i had a few times where i could...
  3. Blue screen 0xc000021A
  4. Reset PC does not work to address 0xc000021a blue screen problem
    Reset PC does not work to address 0xc000021a blue screen problem: I have today had a problem with my PC whereby I get the blue screen with error message 0xc000021a. I have tried repairs, not working, just loops back to same screens. So I tried reset the PC to reinstall windows. Doesn't seem to do anything, I just end up back on same blue...
  5. Reset PC does not work to address 0xc000021a blue screen problem
  6. blue screen 0xc000021a
    blue screen 0xc000021a: cat get safe mode https://answers.microsoft.com/en-us/windows/forum/all/blue-screen-0xc000021a/80570690-bd37-4899-bef5-e65472cddea8
  7. Blue screen with 0xc000021a error
    Blue screen with 0xc000021a error: Help me to fix blue screen with 0xc000021a error. Thanks https://answers.microsoft.com/en-us/windows/forum/all/blue-screen-with-0xc000021a-error/b31000f2-1ca9-4212-909a-5b435f9250eb
  8. Blue Screen Code: 0xc000021a
    Blue Screen Code: 0xc000021a: I keep getting the error code 0xc000021a, i’ve tried scanning my computer through command lines, i’ve tried system restore, i’ve tried to reset my computer, i’ve tried running it in safe mode. Literally nothing has worked every single time I just get the same error message....
  9. Blue screen error 0xc000021a
    Blue screen error 0xc000021a: I reset my network settings. Then my pc gets restart there shows the blue screen error 0xc000021a. I tried to reset the pc, startup repair. When I goes for resetting the pc, it completes upto 60 then says that there was a problem. Even I tried the system restore. But there...
  10. blue screen showing 0XC000021a
    blue screen showing 0XC000021a: For the second time I have an problem that my NVME-M2 Westerndigital black PC SN700, is not accessible for booting Win10, it show only a greyed Localdisk symbol and an NTFS remark. I have solved this by using this Youtube video: It became now accessible but still I could...
