Windows 10: Scaling Problems using 4K Monitor
Discus and support Scaling Problems using 4K Monitor in Windows 10 Graphic Cards to solve the problem; I saw a great deal on a UHD monitor and grabbed it, completely unaware of the issues regarding scaling for programs, particularly older programs, in a... Discussion in 'Windows 10 Graphic Cards' started by TV2, Feb 24, 2019.
Scaling Problems using 4K Monitor - Similar Threads - Scaling Problems using
1080p scaling issues on 4K monitor
in Windows 10 Customization1080p scaling issues on 4K monitor: I have a laptop which uses a 4K screen. The problem is that I want to run intensive programs however I can only run them in lower resolutions such as 1080p as in 4K they are laggy and unusable. The problem is that if I set my computer resolution to 1080p, the ui, especially... -
Windows Scaling - Does this Defeat the Purpose of a 4K Monitor?
in Windows 10 Graphic CardsWindows Scaling - Does this Defeat the Purpose of a 4K Monitor?: Hi, I recently upgraded my monitor to 4K and noticed that Windows Scaling shows the value of 150% as Recommended. Leaving it at 100% is super crisp, clean, but small - the upgraded resolution is obvious. But I find that 150% almost looks like a 1080p resolution... and am... -
4k Monitor Windows Scaling Resolution
in Windows 10 Customization4k Monitor Windows Scaling Resolution: Hi, I have a 4K 2160 x 3840 monitor for my Windows 10 PC.If i use windows display scaling set at 100%, all the icons are tiny, but when i do a screen resolution test using various websites, the results come back as 2160 x 3840.I used websites such... -
Windows 10 4K scaling
in Windows 10 Ask InsiderWindows 10 4K scaling: Hai, I’m planning to buy a new monitor. Preferably one with a high resolution whereas a high DPI/PPI. Online I read that windows 10 had issues with scaling for 4K monitors. Everything looks tiny and to fix that people use the scaling feature. But then some programs look... -
Anyone using a 4K monitor? Scaling issue when snipping?
in Windows 10 Ask InsiderAnyone using a 4K monitor? Scaling issue when snipping?: When you run Windows and you take a screenshot using Snip & Sketch, do you have any weird scaling issues? I have a Windows laptop with 1080p native resolution that is connected to a 4K monitor. When I take screenshots using Snip & Sketch, a weird scaling effect happens where... -
How to scale Remote Desktop on 4k monitor
in Windows 10 Network and SharingHow to scale Remote Desktop on 4k monitor: I have a new 15.6" laptop and 27" external monitor. Both the laptop display and external monitor are 4k. So far the only app that does not scale properly is Remote Desktop. When I RD to another Win 10 Pro system the fonts in the RD window are so small that they are barely... -
in Windows 10 SupportHow to scale Remote Desktop on 4k monitor: I have a new 15.6" laptop and 27" external monitor. Both the laptop display and external monitor are 4k. So far the only app that does not scale properly is Remote Desktop. When I RD to another Win 10 Pro system the fonts in the RD window are so small that they are barely... -
4K and 1080 Monitors problem...
in Windows 10 Graphic Cards4K and 1080 Monitors problem...: I purchased a 4K monitor and also have a 1080 monitor on my system. I have set the size of text, apps and other items in the Display options on the 4k monitor at 150% so its readable, at 100% the text is very small. I have set the 1080 monitor at 100%. The problem is... -
Scaling 1920x1080 to 4K screen
in Windows 10 Graphic CardsScaling 1920x1080 to 4K screen: Hello everyone! I have a question that I have not been able to find a proper answer to, and I'm starting to think it's impossible to do. I recently bought a Dell XPS 15 with a 4K screen. I normally don't care for 4K but I thought it would be useful to futureproof my...
