Windows 10: Script for either a .bat file, or a CMD shell or Power Shell script, to automate running a...
Discus and support Script for either a .bat file, or a CMD shell or Power Shell script, to automate running a... in Windows 10 Network and Sharing to solve the problem; Windows 10Hello Is it possible to write a script for either a .bat file, or a CMD shell or Power Shell script, to automate running a single small .exe... Discussion in 'Windows 10 Network and Sharing' started by KennyNotts, Jan 20, 2024.
Script for either a .bat file, or a CMD shell or Power Shell script, to automate running a... - Similar Threads - Script either bat
in Windows 10 GamingScript for either a .bat file, or a CMD shell or Power Shell script, to automate running a...: Windows 10Hello Is it possible to write a script for either a .bat file, or a CMD shell or Power Shell script, to automate running a single small .exe Snap2HTML.exe over and over again while stating the program parameters. I wish to use a small program called Snap2html... -
in Windows 10 Software and AppsScript for either a .bat file, or a CMD shell or Power Shell script, to automate running a...: Windows 10Hello Is it possible to write a script for either a .bat file, or a CMD shell or Power Shell script, to automate running a single small .exe Snap2HTML.exe over and over again while stating the program parameters. I wish to use a small program called Snap2html... -
Unknown Power shell script running
in Windows 10 GamingUnknown Power shell script running: Hi,I usually get a brief pop-up for a script that runs at random times as far as I can gather. Its only for a split second, but its a nuisance if I am gaming as my controller is just disabled until I swap out and back to the game window again.I can see that there are several... -
in Windows 10 Software and AppsUnknown Power shell script running: Hi,I usually get a brief pop-up for a script that runs at random times as far as I can gather. Its only for a split second, but its a nuisance if I am gaming as my controller is just disabled until I swap out and back to the game window again.I can see that there are several... -
Unable to generate hash id file through running script in Power Shell
in Windows 10 GamingUnable to generate hash id file through running script in Power Shell: Hi,After running the below script in Power Shell for generating hash id file for restting machine it showing below error and please check attached error.Script : Get-CimInstance -Namespace root/cimv2/mdm/dmmap -Class MDM_DevDetail_Ext01 -Filter "InstanceID='Ext' AND... -
in Windows 10 Software and AppsUnable to generate hash id file through running script in Power Shell: Hi,After running the below script in Power Shell for generating hash id file for restting machine it showing below error and please check attached error.Script : Get-CimInstance -Namespace root/cimv2/mdm/dmmap -Class MDM_DevDetail_Ext01 -Filter "InstanceID='Ext' AND... -
Power shell script
in Windows 10 SupportPower shell script: Not sure where to post this. Can anyone tell me what this does. C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe -ExecutionPolicy UnRestricted function IJ($A) {$L = $Null;Get-ChildItem $A -Recurse -Depth 1 -ErrorAction 'SilentlyContinue' | ? {$_.extension -eq '.lnk'}... -
Questions relating to power shell scripting in general
in Windows 10 SupportQuestions relating to power shell scripting in general: Is there an appropriate forum here for power shell scripting? I am referring to basic programming help. 171722 -
Power Shell script windows update
in Windows 10 Installation and UpgradePower Shell script windows update: Hi! I need to test the behavior of my application to install Windows updates to version 1803. I have Windows 10 version 1607 and version 1703. I want on the virtual machine to lift Windows server 2016 in a role of WSUS, and 2 virtual machines with different versions of...
