Windows 10: Setting up different monitor profiles between home and work
Discus and support Setting up different monitor profiles between home and work in Windows 10 Customization to solve the problem; Hello. I'm trying to figure out a way to save a little time in the morning depending on where I am working. At home, I have an ultra wide monitor that... Discussion in 'Windows 10 Customization' started by DenverDietz, May 18, 2021.
Setting up different monitor profiles between home and work - Similar Threads - Setting different monitor
Setting up multiple monitors on different graphics adapters
in Windows 10 Drivers and HardwareSetting up multiple monitors on different graphics adapters: My Windows 10 PC has an Intel HD 4600 graphics co-processor with dual DisplayPort outputs, but DisplayPort #2 is not working. I believe it is a hardware problem. So I have added a NVIDIA GeForce 210 graphics card for the second display.Display Manager / Display Adapters shows... -
Is there a way to swap between different monitors
in Windows 10 CustomizationIs there a way to swap between different monitors: I have currently got 2 monitors, and will shortly have 3. I have 1 set up as my normal monitor for general usage and gaming, and a second monitor separate on a racing simulator. Currently i have to unplug my display port cable from my pc from the monitor in use for windows... -
Different monitor backgrounds for dual monitor set up.
in Windows 10 CustomizationDifferent monitor backgrounds for dual monitor set up.: How do I set dual backgrounds on two different monitors? When I go to personalize and right click on the background picture option where it says "Choose your picture" to set to a specific monitor it gives me three options: Set for all monitors, Set for monitor 2, and Set for... -
Difference between settings & control panel?
in Windows 10 SupportDifference between settings & control panel?: I'm new the the Windows 10 Forums, and actually very new to the Windows 10 operating system (coming from using Apple products). I find it a bit confusing that there seems to be sometimes two places for some settings, for instance I see two different areas for... -
Settings home screen looks different between computers.
in Windows 10 CustomizationSettings home screen looks different between computers.: My settings home screen looks different between my Surface Book and a Surface Go that I own. Both are on the same OS Build of Windows 10 Pro. The Book has no Account info or OneDrive and Widows Update icons at the top. The Surface Go does have that information. Aside from... -
Difference between deleting user profile by different ways
in User Accounts and Family SafetyDifference between deleting user profile by different ways: Profile of a user is corruped in a Domain PC. What is the difference if admin delete the user profile via advance system properties instead from registry editor. 142813 -
difference between microsoft account and user profile
in User Accounts and Family Safetydifference between microsoft account and user profile: Hello.I have windows 10 build 1703.I am confused about differences between microsoft account and user profile.When i am searching or i have a porblem , i don't know which term should I do for the search.So i have some questions: 1) are the same? 2) Can i permanently delete... -
in Windows 10 Supportdifference between microsoft account and user profile: Hello.I have windows 10 build 1703.I am confused about differences between microsoft account and user profile.When i am searching or i have a porblem , i don't know which term should I do for the search.So i have some questions: 1) are the same? 2) Can i permanently delete... -
Beginner question: difference between Home and Home N
in Windows 10 Installation and UpgradeBeginner question: difference between Home and Home N: Which version should I pick and why? Does N version cost more? I'm doing a completely fresh install and I'm going to buy the license after the installation. Also I don't think a need the Pro version. Home or Home N [img] 33242
