Windows 10: Shut down laptop to battery power and power up when reconnected?
Discus and support Shut down laptop to battery power and power up when reconnected? in Windows 10 BSOD Crashes and Debugging to solve the problem; Hello, I wanted to ask if there is a way to shut down my Windows 10 laptop immediately when it is disconnected from the power supply and... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Gr4ph1xZ, Jun 13, 2020.
Shut down laptop to battery power and power up when reconnected? - Similar Threads - Shut down laptop
Power button shuts down laptop, instead of waking it up
in Windows 10 GamingPower button shuts down laptop, instead of waking it up: Since the past 2 weeks, I've been seeing strange behavior in my laptop.When I close the lid, it goes to sleep, but when I press the power button to turn it on, it just shuts down immediately. And doesn't turn on even after pressing power button.Then when I remove the... -
in Windows 10 Software and AppsPower button shuts down laptop, instead of waking it up: Since the past 2 weeks, I've been seeing strange behavior in my laptop.When I close the lid, it goes to sleep, but when I press the power button to turn it on, it just shuts down immediately. And doesn't turn on even after pressing power button.Then when I remove the... -
in Windows 10 Performance & MaintenancePower button shuts down laptop, instead of waking it up: Since the past 2 weeks, I've been seeing strange behavior in my laptop.When I close the lid, it goes to sleep, but when I press the power button to turn it on, it just shuts down immediately. And doesn't turn on even after pressing power button.Then when I remove the... -
Laptop restart after shutting down on battery power
in Windows 10 Performance & MaintenanceLaptop restart after shutting down on battery power: Laptop restart after shutting down on battery power but when connected with charging adapter shut down until power is supplied https://answers.microsoft.com/en-us/windows/forum/all/laptop-restart-after-shutting-down-on-battery/5fdfd35d-bee8-48db-b523-c94de0042d58 -
Power then Shut down Buttons
in Windows 10 Performance & MaintenancePower then Shut down Buttons: My choices were: " Power" then "Sleep Shut Down and Restrart." They are now: "Power",then Sleep Update and Shut Down and Update and Restart When I click on "Update and Shut Down", the machine goes back into Restart at once and then takes a long period of time after... -
Shut down/Power off
in Windows 10 Performance & MaintenanceShut down/Power off: I have an HP laptop with windows 10 home. When I choose start/shut down, it closes everything and screen goes blank, but won't power down (off). It used to work. I have to manually turn it off.... -
power on/shut down
in Windows 10 Performance & Maintenancepower on/shut down: I recently reset my laptop back to the original settings. Ever since when I want to shut down now my laptop I only see Sleep, Update and Shut down and Update and Restart. I don't see the simple Shut down option. I don't want to continually update. How can I get this fixed?... -
laptop shutting down suddenly when power pluged in
in Windows 10 BSOD Crashes and Debugginglaptop shutting down suddenly when power pluged in: laptop shutting down suddenly when power pluged in https://answers.microsoft.com/en-us/windows/forum/windows_10-performance/laptop-shutting-down-suddenly-when-power-pluged-in/3132e0a0-d7fc-4c40-93e6-737c2e552538 -
Power supply running power when I shut down?
in Windows 10 SupportPower supply running power when I shut down?: I have a Corsair CX750M PSU.. These units remain on even after shutting down my system so, should I flip the switch off when I'm not using it or, is it safe to leave that switch on? Thanks! 110637
