Windows 10: shutdown and sleep sound problem
Discus and support shutdown and sleep sound problem in Windows 10 Software and Apps to solve the problem; shutdown and sleep sound problem to fix... Discussion in 'Windows 10 Software and Apps' started by satish chand1, May 25, 2023.
  1. shutdown and sleep sound problem
  2. Sound problem
    • Click Hardware and Sound.
    Radney Dri, May 25, 2023
  3. wiganken Win User
    Windows Shutdown Sound Not Playing
    The last time I allowed shutdown sounds to be played was around 1995. I found them annoying and have never missed them. I just want the PC to shutdown and I don't need a sound to tell me it is shutting down.
    Why not consider disabling sounds and the problem goes away. Just a suggestion.
    shutdown and sleep sound problem 356196d1641111241t-windows-shutdown-sound-not-playing-no-sounds.png
    wiganken, May 25, 2023
  4. Riel Alc Win User
    Windows 10 Shutdown and sleep, IE keeps hanging
    For us to better assist you with your shutdown, sleep and IE issues, we'd like to know the following:
    • Were there any changes made to your computer prior to this issue (e.g. Windows updates)?
    • What troubleshooting steps have you done to resolve the issue?
    We're looking forward to your reply.
    Riel Alc, May 25, 2023
  1. shutdown and sleep sound problem - Similar Threads - shutdown sleep sound
  2. Shutdown or Sleep?
    Shutdown or Sleep?: Hi again, I have been using my Lenovo laptop a number of years now. Starting with Windows 8.1 and now Windows 10. I am normally using it throughout the day on and off. I normally press the "Shutdown" option and even turn it off at the wall each time. Although I press...
  3. Shutdown or Sleep?
  4. shutdown and sleep sound problem
    shutdown and sleep sound problem: shutdown and sleep sound problem to fix https://answers.microsoft.com/en-us/windows/forum/all/shutdown-and-sleep-sound-problem/9274952e-7bd1-46e1-bb35-c08648d4f399
  5. shutdown and sleep sound problem
  6. Shutdown and Sleep Problem
    Shutdown and Sleep Problem: I have Windows 10 in my HP Pavilion 15 Laptop. I am not able to shutdown my laptop even not able to put my laptop on sleep mode. Whenever, I shutdown my laptop its screen became blank and hard disk stop running while power button & Power led still show light. In that...
  7. Sleep/shutdown problems
    Sleep/shutdown problems: I have been suffering from a wake from sleep/on from shutdown problem for a while now. On all current updated windows 10 20.04, chipset drivers for mobo mobo and processor, current radeon drivers for gpu. All current optional windows drivers have been tried as well. My rig:...
  8. sleep mode and shutdown problems
    sleep mode and shutdown problems: My computer takes a lot of time to wake up from sleep mode and to shut down . I think I messed up some drivers while I was trying to fix another problem. What should I do now?...
  9. Sleep and Shutdown
    Sleep and Shutdown: This problem is really ridiculous. There are 3 pc's in the house and the main oneMINE has the problem.I have tried everything in all the previous folks that have the same problem to no sleep or shutdown. I have been just turning off monitors so they aren't damaged,if that...
  10. shutdown sound problem
    shutdown sound problem: I have adjusted registry to allow access to system exit sound, which, by default in win10, is not visible. Having made it visible, even when I change to my preferred wav file, apply it, and play it for confirmation, when I shutdown, I hear only the ms default ding. I am able,...
