Windows 10: So many problems! Error messages. Please read and help if you can
Discus and support So many problems! Error messages. Please read and help if you can in Windows 10 Support to solve the problem; I updated my spec in my profile if that helps Discussion in 'Windows 10 Support' started by Squibbler, Apr 19, 2017.
  1. Squibbler Win User
    Squibbler, Apr 21, 2017
    #31
  2. Squibbler Win User
    Btw I checked the settings in the bios and I think it is already set to legacy if this is the right setting screen
    So many problems! Error messages. Please read and help if you can [​IMG]
    #32
  3. simrick Win User
    Okay that's a problem on your machine because I just downloaded it, extracted it and ran it.
    You're going to have to skip this part for now.
    On to the in-place repair install:
    Select the W10 media tool and plug in an empty flash drive-save the W10 media to that, because you're not going to be able to mount an ISO on your machine.
    View the contents of the newly-created W10 flash drive in file explorer - are you able to do that, or not?
    Run setup.exe from there by double-clicking the file.
    simrick, Apr 21, 2017
    #33
  4. Squibbler Win User
    Ok - will try that tomorrow as it is getting late. One thought - could I try running the ISO file from a CD Rom/ DVD? I could try burning one tomorrow?
    #34
  5. simrick Win User
    Was this thing really "updated" from Vista>W7>W10? No clean installs ever?
    #35
  6. Squibbler Win User
    I also still need to back up my files presumably before doing a repair?
    #36
  7. simrick Win User
    Yes, that is an option as well, but you need to be able to open the ISO to get to the setup.exe inside it. I am thinking you will have the same problems.
    #37
  8. simrick Win User
    Do you have another system you can hook this drive up to (slave) and run CHKDSK /R on it?
    #38
  9. simrick Win User
    I would, just to be safe. *Wink
    #39
  10. Squibbler Win User
    Yes, I bought win 7 myself as an upgrade and when I had a virus a couple of years after - I rebuilt it again I think from an image I made straight after upgrade as clean as I could get it as I had some software I had lost the key for and then of course we all moved to win 10 recently. But it has seemed pretty stable since
    #40
  11. simrick Win User
    Okay. I have seen lots of "baggage" from upgrades - especially with W7>W10 - which are always resolved with a clean install. Just sayin'. *Wink
    #41
  12. Squibbler Win User
    hmm... no not really, just have an ipad
    #42
  13. Squibbler Win User
    I will try some of this tomorrow but I will be out for a large part of the day so it may be Sunday before I get to try it properly and also need to do the backups
    #43
  14. simrick Win User
    No problem - no rush. Take your time.
    #44
  15. Squibbler Win User
    One last thought tonight... are all USB sticks bootable? This was a 4 GB freebee one. I erased all files before downloading that ISO file to it ... is it worth me trying a different stick?
    #45
  1. So many problems! Error messages. Please read and help if you can - Similar Threads - many problems Error
  2. Please can someone help me with the disk read error problem?
    Please can someone help me with the disk read error problem?: I tried the system restore point but it was interrupted saying there was a disk read error. Please can someone help me with the disk read error problem. Whenever I press the Ctrl+Alt+Del keys to restart as instructed, I only hear beeps and it doesn't restart. Please can...
  3. Please can someone help me with the disk read error problem?
  4. Please can someone help me with the disk read error problem?
  5. So I have many problems please help
    So I have many problems please help: Okay, so I have bsod critical process died BUT I forgot my password and here’s the thing, when I last reset my pc it told me to create a pin NOTHING ABOUT A PASSWORD am I able to fix this problem?Also if this can do anything I have a usbThat’s all...
  6. So I have many problems please help
  7. So I have many problems please help
  8. So many errors at once please help
    So many errors at once please help: So lemme start from first like I was using adrenaline 21.4.1 version for my laptop which was creating problems in Fullscreen games so according to Microsoft forums I downgraded and everything was fine until I found that my settings now never opened even the search keeps on...
  9. how to stop computer so can read error message
    how to stop computer so can read error message: When restarting the computer, I've noticed an error message but before I can read it, it completely restarts. Is there a way for me to stop the restart so I can get the error message?...
  10. so many error messages after the new update! please help!!!
    so many error messages after the new update! please help!!!: i don’t even know where to start as far as error messages go but all i know is that yesterday while i was on my dell XPS one 2710, i was prompted a message that it was in need of an update. naturally i agreed bc in my experience updates are supposed to help your computer...
