Windows 10: Solution(s) for Audio & Sound being muffled/crackled/popping/distorted, High DPC Latency...
Discus and support Solution(s) for Audio & Sound being muffled/crackled/popping/distorted, High DPC Latency... in Windows 10 Ask Insider to solve the problem; 100 links, several searches on the web. Many solution that didn't work even after using the registry to change values on PowerSettings, installing the... Discussion in 'Windows 10 Ask Insider' started by /u/HaruRose, Mar 22, 2020.
Solution(s) for Audio & Sound being muffled/crackled/popping/distorted, High DPC Latency... - Similar Threads - Solution Audio Sound
High DPC latency / Sound pops and clicks
in Windows 10 GamingHigh DPC latency / Sound pops and clicks: Heyho technical support,maybe You can help me. What i tried so far:- Update all drivers- deactivated non Microsoft related services msconfigs, services and starts- bought a new soundcard- Updated Bios and changed CPU Power- and a lot more things i can't even rememberOnly... -
High dpc latency causing audio crackling/lag
in Windows 10 GamingHigh dpc latency causing audio crackling/lag: Hello I have been having audio issues ever since I got a new Focusrite Scarlett Solo 3rd gen and a Shure SM7B + cloudlifter. It started off with crackling every couple minutes and then started getting worse and worse as time went on. I thought it mightve been a hardware thing... -
in Windows 10 Software and AppsHigh dpc latency causing audio crackling/lag: Hello I have been having audio issues ever since I got a new Focusrite Scarlett Solo 3rd gen and a Shure SM7B + cloudlifter. It started off with crackling every couple minutes and then started getting worse and worse as time went on. I thought it mightve been a hardware thing... -
DPC Latency Issues, Audio Popping and Crackling Horribly
in Windows 10 Drivers and HardwareDPC Latency Issues, Audio Popping and Crackling Horribly: Hello. For about a week I have been experiencing glitchy, popping, crackling audio, This seems to mainly happen when streaming YouTube videos, Spotify, or any audio over internet while playing through my Focusrite Scarlett interface. When playing through headphones this... -
Audio Crackling/Popping and DPC Latency Issues
in Windows 10 Drivers and HardwareAudio Crackling/Popping and DPC Latency Issues: Hi, I seem to get Audio Crackling and Popping issues, after searching the web for a bit I noticed that this issue is generally tied to DPC Latency so I used LatencyMon to recorded for around 2 hours (stats below). In my case it doesn't seem to happen immediately after... -
in Windows 10 SupportAudio Crackling/Popping and DPC Latency Issues: Hi, I seem to get Audio Crackling and Popping issues, after searching the web for a bit I noticed that this issue is generally tied to DPC Latency so I used LatencyMon to recorded for around 2 hours (stats below). In my case it doesn't seem to happen immediately after... -
Crackling sound on audio recording. High DPC latency ACPI.sys and ndis.sys
in Windows 10 BSOD Crashes and DebuggingCrackling sound on audio recording. High DPC latency ACPI.sys and ndis.sys: Hi, I am having some issues with audio recording that seems to be caused by high DPC latency issues. I record music with a mixer that I is plugged into my laptop through usb. On the record I can hear crackling sounds. I have searched for solutions on many forums and... -
high DPC latency and audio distortion (crackling and popping sounds)
in Windows 10 Drivers and Hardwarehigh DPC latency and audio distortion (crackling and popping sounds): Hi guys, Yesterday evening I was watching some youtube videos when suddenly the sound cut out. I turned the volume back up only to find there was a loud staticky crackling pop as the only audio output. Audio output is fine on headphones. I have a Lenovo Yoga 920 (with... -
Sound Distortion Possibly Caused by High DPC Latency
in Windows 10 SupportSound Distortion Possibly Caused by High DPC Latency: Hello. I have had this issue for a while now and I have not figured out a way to stop it. I have tried reinstalling windows and have updated drivers, but nothing seems to work. DPC latency checker stats are below. [img] Thank you. 81909
