Windows 10: Sound control panel speaker test doesn't work for subwooferKlipsch
Discus and support Sound control panel speaker test doesn't work for subwooferKlipsch in Windows 10 Drivers and Hardware to solve the problem; I have a new Klipsch Promedia 2.1 speakers and set-up 2.1 in the sound control panel using 5.1 and unchecking the rear and center speakers. The 2... Discussion in 'Windows 10 Drivers and Hardware' started by Ed Fresh, Sep 3, 2020.
Sound control panel speaker test doesn't work for subwooferKlipsch - Similar Threads - Sound control panel
Speakers are not working and the speakers icon in the sound control panel is grey
in Windows 10 GamingSpeakers are not working and the speakers icon in the sound control panel is grey: Hi, I recently purposely upgraded to Windows 10 version 1809 from Windows 7. With the Windows 7 and Windows 10 version 1809, I can choose my own default sound icon e.g. I can choose Speakers as default instead of Realtek Digital Output from the sound control panel. With this,... -
in Windows 10 Software and AppsSpeakers are not working and the speakers icon in the sound control panel is grey: Hi, I recently purposely upgraded to Windows 10 version 1809 from Windows 7. With the Windows 7 and Windows 10 version 1809, I can choose my own default sound icon e.g. I can choose Speakers as default instead of Realtek Digital Output from the sound control panel. With this,... -
in Windows 10 BSOD Crashes and DebuggingSpeakers are not working and the speakers icon in the sound control panel is grey: Hi, I recently purposely upgraded to Windows 10 version 1809 from Windows 7. With the Windows 7 and Windows 10 version 1809, I can choose my own default sound icon e.g. I can choose Speakers as default instead of Realtek Digital Output from the sound control panel. With this,... -
Headphones are listed as speakers in Sound control panel
in Windows 10 Drivers and HardwareHeadphones are listed as speakers in Sound control panel: Pretty much when I plug my headphones in from the back, into the green jack, it gets recognized as speakers, whereas when I plug it into my front 3.5mm jack labeled as headphones and microphones, it doesn't detect it at all, so it doesn't even say the speakers are in use..... -
My microphone is considered as a speaker in the sound control panel
in Windows 10 CustomizationMy microphone is considered as a speaker in the sound control panel: Hello everyone !I have a little problem yesterday mi microphone rode was working perfectly, it was plugged on the only headphone available on my laptop and my headphones on an usb sound card, but today after plugging my microphone it was not working anymore, I tried to find... -
Control Panel Sounds: not working
in Windows 10 Drivers and HardwareControl Panel Sounds: not working: Hope the screenshot is clear: [img] In fact the window seems unfamiliar; shouldn't it have check boxes showing which actions have been set? If it's relevant this is Version 1903 (OS Build 18362.418) - - - Updated - - - OK, sorted thanks. I found a suggestion to update... -
in Windows 10 SupportControl Panel Sounds: not working: Hope the screenshot is clear: [img] In fact the window seems unfamiliar; shouldn't it have check boxes showing which actions have been set? If it's relevant this is Version 1903 (OS Build 18362.418) - - - Updated - - - OK, sorted thanks. I found a suggestion to update... -
Sound Control Panel
in Windows 10 CustomizationSound Control Panel: Ever since the new windows updates, Sound Control Panel , also known in the bottom right (from sounds - speaker) as Playback Devices / Recording Devices, this tab has been taken out and we were given some option not many care about (even if they do, a lot of people never... -
Sound Control Panel
in Windows 10 Drivers and HardwareSound Control Panel: Hi.Running a Windows 10 computer.Running headless using Remote Desktop.Only use the computer as a music server.Have a dac connected to computer.In sound panel under playback it's only option is Remote Audio.Dac and other options are not there.Right click to show disabled and...
