Windows 10: Sound does not work even after several fix attempts
Discus and support Sound does not work even after several fix attempts in Windows 10 Drivers and Hardware to solve the problem; After installing a new video card sound does not work: The icon has an X. The troubleshooter does not work Device Manager says This device is working... Discussion in 'Windows 10 Drivers and Hardware' started by Tim06, Jan 18, 2021.
Sound does not work even after several fix attempts - Similar Threads - Sound does several
F11 does not work even after fix
in Windows 10 GamingF11 does not work even after fix: Hi!My F11-button isn't working, tried several applications including Chrome and Edge.I found an answer before about this and followed it.Go into the device manager and uninstall the keyboard and restart the PC. I did it and it worked... For like five presses of the... -
in Windows 10 Software and AppsF11 does not work even after fix: Hi!My F11-button isn't working, tried several applications including Chrome and Edge.I found an answer before about this and followed it.Go into the device manager and uninstall the keyboard and restart the PC. I did it and it worked... For like five presses of the... -
in Windows 10 Drivers and HardwareF11 does not work even after fix: Hi!My F11-button isn't working, tried several applications including Chrome and Edge.I found an answer before about this and followed it.Go into the device manager and uninstall the keyboard and restart the PC. I did it and it worked... For like five presses of the... -
Cumulative Update will not install after several attempts not even with standalone installer
in Windows 10 GamingCumulative Update will not install after several attempts not even with standalone installer: Computer has attempted to download and install Cumulative Update for Windows 11 for x64-based Systems KB5014668Error codes I've received:0x802480140x800700260x800f0988I've tried looking for processes and programs that could be trying to compete with this install and stopping... -
in Windows 10 Software and AppsCumulative Update will not install after several attempts not even with standalone installer: Computer has attempted to download and install Cumulative Update for Windows 11 for x64-based Systems KB5014668Error codes I've received:0x802480140x800700260x800f0988I've tried looking for processes and programs that could be trying to compete with this install and stopping... -
I am writing this after several, several attempts of fixing the issue myself but reading...
in Windows 10 Ask InsiderI am writing this after several, several attempts of fixing the issue myself but reading...: I took my laptop which is MSI GF65 Thin 9SD which is on a Windows 10 64-bit operating system. They said it needed a BIOS update and the issue was resolved. And now 3 days back, the issue repeated itself. The Wifi option is just gone and there's an exclamation mark on the... -
DRIVER_IRQL_NOT_LESS_OR_EQUAL after several BSOD attempt fixes ntsokrnl.exe
in Windows 10 BSOD Crashes and DebuggingDRIVER_IRQL_NOT_LESS_OR_EQUAL after several BSOD attempt fixes ntsokrnl.exe: Hello,Not that long ago I used to get BSODS randomly and constantly when idling and used windows driver verifier and removed the offending drivers till I was able to boot via driver verifier. Everything was fine for a while and I recently started to get BSODS again while... -
Headset Mic will NOT work - several attempts
in Windows 10 Ask InsiderHeadset Mic will NOT work - several attempts: Hi. I recently got done switching a prebuilt HP Omen over to a Corsair 4000d Airflow case. The case has a combo-jack on the front panel. This was the same as my old one, where my headset worked perfectly. It fit into my motherboard exactly the same. Now, my only issue is my... -
Wireless Driver not functioning properly after several fix attempts
in Windows 10 Network and SharingWireless Driver not functioning properly after several fix attempts: Hello, I've finally come here because I've became clueless in the matter: (TL;DR and info below) In order for everyone to understand; here goes: It all started with a random wireless problem on Windows 10 (AU) after a restart, before that there was nothing installed or...
