Windows 10: Sound in monitor connected with a hdmi cable
Discus and support Sound in monitor connected with a hdmi cable in Windows 10 Software and Apps to solve the problem; When I connect the laptop to a monitor with a hdmi cable, I can watch the video but don´t listen the audio.I´ve reviewed the driver sound intel R for... Discussion in 'Windows 10 Software and Apps' started by FernandP. Marquand, Jan 14, 2022.
Sound in monitor connected with a hdmi cable - Similar Threads - Sound monitor connected
HDMI Cable to Use External Monitor
in Windows 10 GamingHDMI Cable to Use External Monitor: My question is not related to a Microsoft product other than Windows, I suppose. I apologize if this is not the correct place for my question.I almost exclusively use an external monitor when using my small screen laptop. I have to disconnect and re-connect the HDMI cable... -
in Windows 10 GamingSound in monitor connected with a hdmi cable: When I connect the laptop to a monitor with a hdmi cable, I can watch the video but don´t listen the audio.I´ve reviewed the driver sound intel R for displays and it show that it´s windows/system32 but my laptop is windows System 64.I´m believed that perhaps the problem is on... -
in Windows 10 Drivers and HardwareSound in monitor connected with a hdmi cable: When I connect the laptop to a monitor with a hdmi cable, I can watch the video but don´t listen the audio.I´ve reviewed the driver sound intel R for displays and it show that it´s windows/system32 but my laptop is windows System 64.I´m believed that perhaps the problem is on... -
No sound from HDMI connected monitor
in Windows 10 CustomizationNo sound from HDMI connected monitor: The sound quit working on my HDMI connected monitor. It says headphone or speaker unplugged. I'm pretty sure some update caused it. I have a Dell Inspiron Desktop.... -
connect ps3 by hdmi cable
in Windows 10 Drivers and Hardwareconnect ps3 by hdmi cable: how do I connect a ps3 using a regular hdmi cable to a Lenovo ideapad https://answers.microsoft.com/en-us/windows/forum/all/connect-ps3-by-hdmi-cable/7d13e683-b73b-4803-a6d5-56caefb75553 -
No display on secondary monitor when connected using HDMI cable
in Windows 10 Drivers and HardwareNo display on secondary monitor when connected using HDMI cable: Hi, I am using a Windows 10 laptop, I have a problem where my second display which is connected via HDMI is detected and seems to get a signal as it turns on but it doesn't display an image. My primary monitor uses the internal Intel gpu while my secondary is using the... -
sound with hdmi cable
in Windows 10 Drivers and Hardwaresound with hdmi cable: I connected my computer with an hdmi cable to my tv and the display and sound worked fine. But every time that I wake my computer up after that I have no sound unless I disconnect and then reconnect the hdmi cable to the tv. How can this be resolved without having to... -
No sound to tv through hdmi cable
in Windows 10 CustomizationNo sound to tv through hdmi cable: I have a tv hooked up to my laptop through an HDMI cable. The display comes across beautifully, but there is no sound. I've found my tv, but it gives me no options. When I went into the settings and got to the playback devices, it says the HDMI isn't plugged in. I'm forced... -
No sound using TV as monitor with HDMI cable
in Windows 10 Drivers and HardwareNo sound using TV as monitor with HDMI cable: I use my tv as a monitor for my computer and the sound has suddenly stopped working. The picture is fine but there's no sound, it says that the "Spatial sound" is off and doesn't give me an option to turn the sound on for anything but headphones. Nothing I've seen online...
