Windows 10: Sound problem involving fluctuating sound levels
Discus and support Sound problem involving fluctuating sound levels in Windows 10 Customization to solve the problem; My sound is jumping from 100% to 67% and back again. This repeats itself consistently. Observed in the App Volume Device Preferences place.... Discussion in 'Windows 10 Customization' started by AaronTeng1, Dec 3, 2020.
Sound problem involving fluctuating sound levels - Similar Threads - Sound problem involving
sound level changes by itself
in Windows 10 Software and Appssound level changes by itself: For the last several months the system sound level will change by itself. It doesn't happen often but it does happen. I'm wondering what causes the sound level to change by itself and what to do about it. I set the system sound level at 22%. Just today it changed itself to... -
sound level on the sound system
in Windows 10 Gamingsound level on the sound system: The system sound on my laptop cannot be changed directly, if the sound is made to zero then the sound is off, and if louder has same sound level . sound must customized from settings of the running application.... -
in Windows 10 Software and Appssound level on the sound system: The system sound on my laptop cannot be changed directly, if the sound is made to zero then the sound is off, and if louder has same sound level . sound must customized from settings of the running application.... -
Weird sound level
in Windows 10 Ask InsiderWeird sound level: [ATTACH] Hello there, I have a weird thing on my computer and wondered if anyone has ever seen that. It make the headset sound not increase in a straight line, but more like a parable. So when the sound is not 100%, it is greatly reduced. Sound level at 92 Sound... -
Microphone Sound Level Changing
in Windows 10 CustomizationMicrophone Sound Level Changing: I'm trying to adjust my microphones volume level by setting the level manually then using and voice recorder program to hear how it sounds. My computer however is automatically changing the volume level to what it thinks it should be when I speak and it is too high. How do I... -
Apparent sound problems regarding the volume level
in Windows 10 Ask InsiderApparent sound problems regarding the volume level: Thank you to anyone who reads this. The problem I have is that one day, out of nowhere, even with the volume at 100, my laptop speakers sound very low, almost like they had no sound. I did look it up and it tells me to go to a tab in the sound control panel called... -
Sound Fluctuation
in Windows 10 BSOD Crashes and DebuggingSound Fluctuation: Ever since I updated my laptop on 10/8/2019 I've had an issue with the audio slowing fluctuating up and down. For Example when watching a youtube video my volume would be set to 30. Throughout the duration of the video it sounds as if the volume fades away and then jumps back... -
sound level of adverts
in Windows 10 Software and Appssound level of adverts: Why is it that those adverts MS is pushing have such high volume levels? Or is that just another devious way to try to get people pay for what always has been a free game.... I have adjusted the sound levels of my games, programmes etc so that they are just like I want them... -
sound levels
in Windows 10 Customizationsound levels: I have been using Windows 8 for four years with great sound. We changed to Windows 10 recently and since then the sound levels are pathetic, really low. Both on headphones and without them. I have a Lenovo Thinkpad laptop. Anyone have some input? Thanks, biddy...
