Windows 10: Sound Slider disappeared when changing volume with external volume controls
Discus and support Sound Slider disappeared when changing volume with external volume controls in Windows 10 Gaming to solve the problem; Hello. I have been using a Logitech G213 to control my volume and to skip songs while listening to music. But now suddenly the popup that happens while... Discussion in 'Windows 10 Gaming' started by Jacob Thaddeus Noel L., Jan 31, 2023.
Sound Slider disappeared when changing volume with external volume controls - Similar Threads - Sound Slider disappeared
Headphones Volume no longer controlled via their external volume slider and instead stuck...
in Windows 10 GamingHeadphones Volume no longer controlled via their external volume slider and instead stuck...: I dont know how well to describe this, Ive had this problem since last night. Anyway all of sudden my external and wired headphones Turtle Beach Earforce X12 which I have used perfectly fine they are also pretty newish suddenly stopped working properly. Now sound DOES come... -
in Windows 10 Software and AppsHeadphones Volume no longer controlled via their external volume slider and instead stuck...: I dont know how well to describe this, Ive had this problem since last night. Anyway all of sudden my external and wired headphones Turtle Beach Earforce X12 which I have used perfectly fine they are also pretty newish suddenly stopped working properly. Now sound DOES come... -
in Windows 10 Drivers and HardwareHeadphones Volume no longer controlled via their external volume slider and instead stuck...: I dont know how well to describe this, Ive had this problem since last night. Anyway all of sudden my external and wired headphones Turtle Beach Earforce X12 which I have used perfectly fine they are also pretty newish suddenly stopped working properly. Now sound DOES come... -
Volume slider does not affect sound volume at all
in Windows 10 GamingVolume slider does not affect sound volume at all: I use HP 14s-fq0011au with windows 11 version 22H2 Build 22621.1344The volume slider does not work at all, it will not impact the output sound volume. My work around is by going to volume mixer and use the volume slider for the apps. how to fix this ? I already use the latest... -
in Windows 10 Software and AppsSound Slider disappeared when changing volume with external volume controls: Hello. I have been using a Logitech G213 to control my volume and to skip songs while listening to music. But now suddenly the popup that happens while doing this has stopped showing up. This has prevented me from skipping through music and has become a hindrance. I hope... -
No sound feedback when changing volume with taskbar volume slider
in Windows 10 CustomizationNo sound feedback when changing volume with taskbar volume slider: No sound feedback when changing volume with volume slider but i can hear the sound feedback when i change the volume from inside sound settings in windows settings , every thing is working fine regarding my sound drivers and settings , i have only this issue... -
in Windows 10 CustomizationNo sound feedback when changing volume with volume slider: Hello, I'm getting no notification sound when I increase/decrease volume from task bar. So, as a result, I am unable to hear how loud is the new volume of sound. Also, the system is able to play music normally and other sound notifications. Note that the Windows "sound"... -
Volume Slider suddenly disappeared
in Windows 10 CustomizationVolume Slider suddenly disappeared: Hi There My volume slider in Windows 10 suddenly disappeared. Usually I click once on the volume icon on the task bar and the volume slider appears and I can easily adjust the volume. The volume icon is still appearing on the task bar next to the wifi icon but when I... -
No Beep Sound On Windows 10 Volume Control Slider
in Windows 10 CustomizationNo Beep Sound On Windows 10 Volume Control Slider: I have tried every adjustment I know and on Google info and still can't solve the problem. I have sound accept on the sound adjustment slider in the task bar. Can anyone point me to the right directions on solving this problem. Thanks...
