Windows 10: Spatial sound: Dolby vs Built in + Working with Bluetooth headphones?
Discus and support Spatial sound: Dolby vs Built in + Working with Bluetooth headphones? in Windows 10 Ask Insider to solve the problem; I want to get a better sensation of space when racing in my sim. I found this built in spatial settings in Win 10, but also some other option(s). Whats... Discussion in 'Windows 10 Ask Insider' started by /u/Fluchbyrdz, Feb 16, 2020.
Spatial sound: Dolby vs Built in + Working with Bluetooth headphones? - Similar Threads - Spatial sound Dolby
Headphone treated as speaker can't use spatial sound dolby
in Windows 10 BSOD Crashes and DebuggingHeadphone treated as speaker can't use spatial sound dolby: I have an laptop dell Inspiron 5558 and used to use spatial sound normally until I had to manually re-install windows due to a hardware problem and since then my headphone is displayed and treated as a speaker, therefore, not able to use Dolby or any other spatial sound. The... -
Dolby, DTS and Spatial Sound greyed out
in Windows 10 Drivers and HardwareDolby, DTS and Spatial Sound greyed out: Following a recent issue. I had to do a fresh install of Win 10. Following that said install, settings for Dolby, DTS and Spatial Sound are completely greyed out. I had access to all of them as I do have the hardware requirements met. I believe it could be just a matter of... -
The Dolby Atmos for Headphones (Spatial Sound) for Windows 10 problem
in Windows 10 Ask InsiderThe Dolby Atmos for Headphones (Spatial Sound) for Windows 10 problem: [ATTACH] The Dolby Atmos for Headphones (Spatial Sound) for Windows 10 always gets back to turned off every long time of shut down. Does it really not save the setting for spatial sound? There are times that the setting doesn't save, there are times there is. PS. I bought... -
Spatial sound windows sonic and dolby atmos for headphones/home theater settings are not...
in Windows 10 Drivers and HardwareSpatial sound windows sonic and dolby atmos for headphones/home theater settings are not...: cSir someone has tampered my windows 10 PC's spatial sound coding feature... Since yesterday I am unable to upscale any Dolby digital; Dolby digital plus; Dolby true HD content into full Dolby atmos. Even though I have enabled Dolby atmos for headphones via the Dolby Access... -
Dolby atmos not showing in Spatial sound
in Windows 10 Ask InsiderDolby atmos not showing in Spatial sound: Couldn't update Dolby access so I uninstalled everything and tried to reinstall it. Now there is no Dolby Atmos options and only windows sonic Help :((( submitted by /u/AggerDagger [link] [comments]... -
Dolby Atmos Spatial Sound not enabling
in Windows 10 Drivers and HardwareDolby Atmos Spatial Sound not enabling: So, I did figure this out. I found another thread only 1!!! and ive been all over the internet trying to figure it out but i already kind of had an idea of what may of caused the issue. My Dolby Atmos Sound wouldnt enable. I could do windows sonic but when id click atmos... -
Dolby Atmos for headphones not selectable in spatial sound
in Windows 10 CustomizationDolby Atmos for headphones not selectable in spatial sound: I recently installed Dolby Access from the Microsoft store to trial Dolby Atmos for headphones. During the trial I was able select Dolby Atmos for headphones in spacial sound settings but after purchasing the license the option is now gone, I am only able to select Off and... -
'Dolby Access for Headphones' options is not visible in spatial sound
in Windows 10 Drivers and Hardware'Dolby Access for Headphones' options is not visible in spatial sound: After the recent update, i am not able to see the option 'Dolby Access for Headphones' option in spatial sound. Before the update i was able to view the option and the functionality has been working fine. Please suggest on how to enable this feature again. Operating System:... -
Dolby Atmos Headphones Spatial viritual surround sound 7.1 on or off?
in Windows 10 Drivers and HardwareDolby Atmos Headphones Spatial viritual surround sound 7.1 on or off?: The option "turn on 7.1 virtual surround sound" Do you need to turn this on or off in use with Dolby Atmos for headphones? I read you need to disable "enhancements" when using Dolby Atmos However since the 7.1 virtual sound option is in the tab of spatial audio, where...
