Windows 10: Start menu keeps going weird! Still no solution to my problem!
Discus and support Start menu keeps going weird! Still no solution to my problem! in Windows 10 Support to solve the problem; Hey guys I've literally asked on every forum i can think of about this problem and still haven't found a solution *Sad Imgur: The most awesome... Discussion in 'Windows 10 Support' started by jmshdtv, Jul 24, 2016.
Start menu keeps going weird! Still no solution to my problem! - Similar Threads - Start menu keeps
Very weird problem and only happens at the start menu
in Windows 10 Ask InsiderVery weird problem and only happens at the start menu: [ATTACH] submitted by /u/MoeNancy [link] [comments] https://www.reddit.com/r/Windows10/comments/e6el29/very_weird_problem_and_only_happens_at_the_start/ -
weird problems with start menu and settings
in Windows 10 Ask Insiderweird problems with start menu and settings: Its my first post in this subreddit so be kind. I do tech support, so for me this one is weird In the last couple of days my main win10 machine has problem with the start power icon having no effect(right clicking works) and if i go to settings i can't type anything into the... -
Start Menu not working possible solution
in Windows 10 Performance & MaintenanceStart Menu not working possible solution: I have been fighting with the start menu and many of the windows apps not working after leaving the computer for a while. With some of the apps, I could close them and restart. I am using a Laptop with two external monitors. I tried all the fixes I could find out there,... -
SOLUTION - Start menu disappears, start menu will not open [Solved]
in Windows 10 CustomizationSOLUTION - Start menu disappears, start menu will not open [Solved]: PROBLEM STATEMENT: All of the sudden one day the Start Menu in Win 10 stopped working, clicking the button or pressing the Win key had no effect. After spending hours exploring all manner of weird and wonderful *hacks* on the Internets to no effect I have stumbled across... -
Start menu weird folder icons
in Windows 10 CustomizationStart menu weird folder icons: Hello, Since some Windows 10 versions, I often have "weird" start menu folder icons, usually when resuming my laptop from sleep mode. The Windows 10 is always a clean install, and I have seen the issue with both Microsoft and HP drivers. Here's an example on how the... -
Weird start menu problem, I've been searching for hours
in Windows 10 SupportWeird start menu problem, I've been searching for hours: I just Installed windows 10 pro on my new PC at work. And my start menu looks like this [img] The icons on the left are unclear and annoying to get used to. I've been looking on the net and saw that the majority of the screenshots of the start menu on windows 10 look like... -
Where did my start menu go?
in Windows 10 SupportWhere did my start menu go?: Hi guys! Last night my computer restarted and did some updates, and this morning I no longer have a start menu? I can right click on the task bar to get a context menu, but hitting the windows symbol, or pressing the windows key on my keyboard no longer works! Task... -
Weird Start Menu
in Windows 10 SupportWeird Start Menu: Hi Guys This is my first post so please be gentle with me. I've been a member for a while now and before making my first post i've used the search facility until i ran out of keywords to use and couldn't find anything similar to my problem. I have virtually no tiles... -
Start menu, still messy?!
in Windows 10 SupportStart menu, still messy?!: Any option, to make my start menu a little bit useful? I only have 4 recelty installed apps on the top, the rest of it is full of softwares in aphabetical order *Sad I dont care of those, but there is no option to hide them. SHow me a video, or any instruction, how to...
