Windows 10: Start / Power problem
Discus and support Start / Power problem in Windows 10 Customization to solve the problem; When I click on "Start" then "Power" there are two messages shown. "Update & Shut down" and "Update & Restart". They both have an orange dot on the... Discussion in 'Windows 10 Customization' started by DavidBellNo1, Dec 27, 2019.
Start / Power problem - Similar Threads - Start Power problem
power button on starting
in Windows 10 Software and Appspower button on starting: i am click on power button but not started my computer this is less time consume https://answers.microsoft.com/en-us/windows/forum/all/power-button-on-starting/6f5d4176-2479-43b7-8885-8ca568e25338 -
in Windows 10 Gamingpower button on starting: i am click on power button but not started my computer this is less time consume https://answers.microsoft.com/en-us/windows/forum/all/power-button-on-starting/6f5d4176-2479-43b7-8885-8ca568e25338 -
Power problem
in Windows 10 GamingPower problem: HelloMy laptop doesn't boot until i remove the battery and plug the charger in, after that i put the battery and unplug the the ac adapter and the laptop works fine for almost 12 hours, then the next day i should do the same process to boot it again.What is the problem and... -
Power problem
in Windows 10 Software and AppsPower problem: HelloMy laptop doesn't boot until i remove the battery and plug the charger in, after that i put the battery and unplug the the ac adapter and the laptop works fine for almost 12 hours, then the next day i should do the same process to boot it again.What is the problem and... -
Power problem
in Windows 10 CustomizationPower problem: HelloMy laptop doesn't boot until i remove the battery and plug the charger in, after that i put the battery and unplug the the ac adapter and the laptop works fine for almost 12 hours, then the next day i should do the same process to boot it again.What is the problem and... -
Power problem
in Windows 10 Performance & MaintenancePower problem: The cpu stays on after sutdown and won't bootup without reconnecting power.This suddenly happened and we treated with every opinions posted online:Power reset,disabling fast startup,using cmd prompt and even reinstalled a new win 10 pro but again it won't shut down.I come... -
Power on problem
in Windows 10 Performance & MaintenancePower on problem: I recently gave my old PC to my grand-daughter who does not live with me. when she trys to switch the PC on it will not power up until she tilts the box. Today I took the side of the tower off and successfully started the PC a number of times however when I replaced the... -
power problems
in Windows 10 BSOD Crashes and Debuggingpower problems: The external hard drive is connected and I have to press the power button twice to get the login page. Is there a solution like an update the settings on my Toshiba laptop. https://answers.microsoft.com/en-us/windows/forum/all/power-problems/1b53e062-a6de-4549-bec4-23f74122fbc0 -
Power problem
in Windows 10 SupportPower problem: My computer was working great until about 3 or 4 weeks ago. Now for some reason when its inactive for about 5 minutes the screen will go dark and moving the mouse to reactivate the screen, it takes a minute or two for the display to come back. Also when the computer is...
