Windows 10: Surface book: Battery 2 (Keyboard) not charging and volume button opening ctrl+alt+del menu
Discus and support Surface book: Battery 2 (Keyboard) not charging and volume button opening ctrl+alt+del menu in Windows 10 Customization to solve the problem; The laptop's been working fine over the past couple of years, but now it's just not working as intended. When i press the volume down button, it... Discussion in 'Windows 10 Customization' started by RIP PYTHON, Sep 20, 2019.
Surface book: Battery 2 (Keyboard) not charging and volume button opening ctrl+alt+del menu - Similar Threads - Surface book Battery
Surface book 2 battery not charging
in Windows 10 Software and AppsSurface book 2 battery not charging: Hello,Unfortunately there was coffee spilled on the surface book. We let it dry and started a couple days later. Everything works fine, but the battery won't charge, it works if it's connected though.When we disconnect the tablet, we can charge the tablet battery, but not the... -
in Windows 10 BSOD Crashes and DebuggingSurface book 2 battery not charging: Hello,Unfortunately there was coffee spilled on the surface book. We let it dry and started a couple days later. Everything works fine, but the battery won't charge, it works if it's connected though.When we disconnect the tablet, we can charge the tablet battery, but not the... -
in Windows 10 GamingSurface book 2 battery not charging: Hello,Unfortunately there was coffee spilled on the surface book. We let it dry and started a couple days later. Everything works fine, but the battery won't charge, it works if it's connected though.When we disconnect the tablet, we can charge the tablet battery, but not the... -
When I presse the alt key it opens the "ctrl+alt+del menu"
in Windows 10 GamingWhen I presse the alt key it opens the "ctrl+alt+del menu": When i press alt it override everthing! The right alt key is fine this issue is only on the left alt key. https://answers.microsoft.com/en-us/windows/forum/all/when-i-presse-the-alt-key-it-opens-the-ctrlaltdel/e109b53c-91f1-403b-ab72-63c03f46423e -
in Windows 10 Software and AppsWhen I presse the alt key it opens the "ctrl+alt+del menu": When i press alt it override everthing! The right alt key is fine this issue is only on the left alt key. https://answers.microsoft.com/en-us/windows/forum/all/when-i-presse-the-alt-key-it-opens-the-ctrlaltdel/e109b53c-91f1-403b-ab72-63c03f46423e -
Battery Not Charging on Surface Book
in Windows 10 Drivers and HardwareBattery Not Charging on Surface Book: I have a surface book with Windows 10. After my last update last week odd things started happening. The battery refused to charge above 20% and various battery power savings had been switched on that I didn't ask for. I've managed to switch off these savers and my battery... -
Ctrl+Alt+Del
in AntiVirus, Firewalls and System SecurityCtrl+Alt+Del: When I start the computer it is locked. It is asking for Ctrl+Alt+Del to be entered. When I do this there is no response. I cannot get to the password entry; the keyboard doesn't respond. How do I fix this?... -
Surface Pro or Surface Book battery not charging
in Windows 10 NewsSurface Pro or Surface Book battery not charging: [ATTACH] Surface devices, especially the Surface Book devices are pretty complex. The Surface Book’s display can be taken off to be used as a tablet whereas the Surface Pro is a tablet which gets an external keyboard (type cover) and a [...] This post Surface Pro or Surface... -
CTRL + ALT + DEL menu not rendered at the top
in Windows 10 SupportCTRL + ALT + DEL menu not rendered at the top: This is a terribly annoying problem. Whenever I play a game such as Garry's mod which is running on the old source engine and tends to freeze while joining servers, force quitting it with CTRL + ALT + DEL is completely impossible. The issue is that whenever I press CTRL +...
