Windows 10: Surface Pro 4 Battery Drain during Sleep / Heating
Discus and support Surface Pro 4 Battery Drain during Sleep / Heating in Windows 10 Support to solve the problem; I wasn't able to specifically find this item on this forum, but post-build 1511 the Surface Pro 4 has excessive battery drain during sleep (like ~10... Discussion in 'Windows 10 Support' started by PJLLB, Nov 20, 2015.
Surface Pro 4 Battery Drain during Sleep / Heating - Similar Threads - Surface Pro Battery
Battery draining generally and during sleep
in Windows 10 Performance & MaintenanceBattery draining generally and during sleep: I have Huawei matebook book 14 i7 for 2 months nowThe laptop battery generally is draining more rapidly than it was before I could estimate that the battery drains after 6 hours only of activity with no video playback and it used to last longer than that, also the battery... -
in Windows 10 GamingBattery draining generally and during sleep: I have Huawei matebook book 14 i7 for 2 months nowThe laptop battery generally is draining more rapidly than it was before I could estimate that the battery drains after 6 hours only of activity with no video playback and it used to last longer than that, also the battery... -
in Windows 10 Software and AppsBattery draining generally and during sleep: I have Huawei matebook book 14 i7 for 2 months nowThe laptop battery generally is draining more rapidly than it was before I could estimate that the battery drains after 6 hours only of activity with no video playback and it used to last longer than that, also the battery... -
Battery drain during sleep
in Windows 10 Performance & MaintenanceBattery drain during sleep: Hello, I have a problem with my Microsoft Surface Pro 7 running on Windows 10 Home when closing the lid putting it in sleep mode, not hibernation. The problem seems to mainly appear after having it connected to an HDMI device/beamer. The laptop experiences a significant... -
Surface Pro 4 Battery issues
in Windows 10 Performance & MaintenanceSurface Pro 4 Battery issues: I decided to charge the battery with the charger that came with the surafce. Unfortunately,despite having power through the charger and the charger looking as good as new, with no damage seen and the white light being on the side port. The battery is not charging or holding... -
in Windows 10 Performance & MaintenanceBattery drain during sleep: I have a first gen Microsoft Surface Laptop, with the Core i5 and 8gb RAM. When I close the lid, putting it into sleep mode, the battery still drains quite a lot. For example, if I leave it in sleep over night, the battery can easily go down by 30% or more. During use, the... -
Surface Pro 4 battery drained out while its off. Why is this happening?
in Windows 10 Performance & MaintenanceSurface Pro 4 battery drained out while its off. Why is this happening?: I am getting frustrated with this issue, really suffer. Further to the response by Edd in the post link: https://answers.microsoft.com/en-us/surface/forum/all/surface-pro-4-huge-battery-drain-whilst-off/9ff401f4-d4b7-4ea6-8de1-54953d38f76c I do have the same issue raised by... -
heating and battery draining issues.
in Windows 10 BSOD Crashes and Debuggingheating and battery draining issues.: Hello, after October update my laptop is getting heat and draining more battery. Task manager shows hing cpu usage. https://answers.microsoft.com/en-us/windows/forum/all/heating-and-battery-draining-issues/f965214f-c30e-4a59-8e93-96dd704900f4 -
Battery not charging Surface Pro 4
in Windows 10 Performance & MaintenanceBattery not charging Surface Pro 4: Hi Ive done all the usial ACPi uninstall reset options It seems that i have to take the charger off and on again 3 times, the pc starts charging Then after 20 secs it stops Have to repeat the 3 times thing After 20 secs it stops Really odd...
