Windows 10: Surface pro 4 battery shows 255% after 1909 update and it no longer work without power...
Discus and support Surface pro 4 battery shows 255% after 1909 update and it no longer work without power... in Windows 10 BSOD Crashes and Debugging to solve the problem; It happened on June 18th, 2021. I was working on my Surface Pro 4 in the morning. Before lunch, I started the 1909 update and had it installed. After... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Samuel_ByTheBay, Jun 29, 2021.
Surface pro 4 battery shows 255% after 1909 update and it no longer work without power... - Similar Threads - Surface pro battery
Surface Pro 4 Battery issues
in Windows 10 Performance & MaintenanceSurface Pro 4 Battery issues: I decided to charge the battery with the charger that came with the surafce. Unfortunately,despite having power through the charger and the charger looking as good as new, with no damage seen and the white light being on the side port. The battery is not charging or holding... -
Hello no longer working on surface pro 4 after the "2004" update but camera works fine
in Windows Hello & LockscreenHello no longer working on surface pro 4 after the "2004" update but camera works fine: Cumulative update 2004 on 8-14-2020 is not allowing face recognition. The camera light & busy led no longer turn on like they use to when attempting hello recognition. There is a yelllow bang at the hello driver and all update attempts report I have the latest driver.... -
laptop battery showing 255% charged and not working
in Windows 10 BSOD Crashes and Debugginglaptop battery showing 255% charged and not working: hi my laptops doesnt boot up if it is not plugged in for 7 months now it always says plugged in not charging today it says charging 255% availaible but if u clcik battery sign it says 100% available and u remove charger it turns o\ff... -
Surface Pro 4 window update 10 Multiple Monitors no longer working
in Windows 10 Drivers and HardwareSurface Pro 4 window update 10 Multiple Monitors no longer working: Before the update I had the surface pro 4 hooked up to two external monitors. One connected directly and the second through a docking station. It now will display on the one directly hooked up but the other connected by docking station will not. I went in to display and to... -
255% on battery?
in Windows 10 Ask Insider255% on battery?: [ATTACH] submitted by /u/AahYush [link] [comments] https://www.reddit.com/r/Windows10/comments/exnqte/255_on_battery/ -
in Windows 10 BSOD Crashes and DebuggingSurface pro 4 battery shows 255% after 1909 update: My surface pro 4 shows 255% battery after update and runs really slow. Ive tried reinstalling drivers and resetting windows. How do I fix this.... -
Surface Pro 4 speakers and pen no longer working
in Windows 10 Drivers and HardwareSurface Pro 4 speakers and pen no longer working: Hello, My speakers and pen on my Surface Pro 4 both stopped working. Both are installed and recognized, but are not functional. I've updated drivers and reset the Surface but don't know what to do. Can anyone please confirm the drivers for these items? Maybe I can... -
Battery not charging Surface Pro 4
in Windows 10 Performance & MaintenanceBattery not charging Surface Pro 4: Hi Ive done all the usial ACPi uninstall reset options It seems that i have to take the charger off and on again 3 times, the pc starts charging Then after 20 secs it stops Have to repeat the 3 times thing After 20 secs it stops Really odd... -
Surface Pro 4 Updates
in Windows 10 Software and AppsSurface Pro 4 Updates: Surface Pro 4 Updates 24 May.. 51325
surface pro 4 255%
