Windows 10: Surface Pro 4 reset. Now start menu, edge, cortana, system, etc.. wont launch.
Discus and support Surface Pro 4 reset. Now start menu, edge, cortana, system, etc.. wont launch. in Windows 10 BSOD Crashes and Debugging to solve the problem; Hello everyone, I have seen this issue a lot, but so far none of the solutions posted have worked. The surface is literally straight off a reset where... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by LawrenceP_Luigi, Apr 18, 2020.
Surface Pro 4 reset. Now start menu, edge, cortana, system, etc.. wont launch. - Similar Threads - Surface Pro reset
Surface pro 4 wont start after update.
in Windows 10 Installation and UpgradeSurface pro 4 wont start after update.: This Monday, I updated my surface pro 4 to the latest windows update available. I think it was 2020-10 Cumulative Update Preview for Windows 10 Version 2004 for x64-based Systems KB4580364. When the update was complete, I chose "Update and shutdown" option from the power and... -
Recovery->Reset PC and now the start button, edge browser, cortana, etc.. won't open
in Windows 10 Ask InsiderRecovery->Reset PC and now the start button, edge browser, cortana, etc.. won't open: Hello guys. I did the reset on the pc to wipe everything including personal files and then it gave me two options: one faster wipe if I'm keeping for myself an one longer wipe if I'm recycling pc. I chose the faster one because I didn't want to wait. After boot I'm expecting... -
Surface pro 4 won’t reset
in Windows 10 BSOD Crashes and DebuggingSurface pro 4 won’t reset: Hi, I have problems getting my surface to work. I have reported this in this thread https://answers.microsoft.com/en-us/windows/forum/windows_10-files/windows-explorer-keeps-resetting/7e71b114-5f14-4025-8913-e70db50d8fea?messageId=27c843b2-de86-49a8-bf1d-5ff5bf5be683 In... -
Start, Cortana,Edge & Search Menu
in CortanaStart, Cortana,Edge & Search Menu: Hi, can anyone help me out with this? Start, Cortana, Edge & Search Menu are no longer working correctly after downloading Windows 10 Pro 1903 OS Build 18362.329 32 bitX64 for 86 based systems(KB 4512941) Aug 30 update. I've still got the start button & search bar but it... -
Start menu, cortana and edge not working
in Windows 10 SupportStart menu, cortana and edge not working: So i have an msi laptop which has been amazing, i stopped using it for a while, decided id start it back up. I did a system refresh, removing everything so i could start fresh, set it all up and my start button doesn't work, so i reset and still nothing... i have watched so... -
Surface Pro 4 No Start Menu, Search, Cortana, Edge
in CortanaSurface Pro 4 No Start Menu, Search, Cortana, Edge: All of the below items don't work: .-Start menu inaccessible .- Search bar doesn't do anything .-Cortana doesn't work .-Can't access windows update "package not registered" Best Regards Terrance... -
Surface Pro 4 - No Start Menu, Search, Cortana, Edge
in Windows 10 BSOD Crashes and DebuggingSurface Pro 4 - No Start Menu, Search, Cortana, Edge: I have a surface pro 4 and recently did a totally clean re-installation for Windows 10.. Machine is just over 12 months old.. and all of the below items don't work: * Start menu inaccessible * Search bar doesn't do anything * Cortana doesn't work * Microsoft edge doesn't... -
Start menu buttons wont launch
in Windows 10 Software and AppsStart menu buttons wont launch: So today my computer stopped running the apps in the start menu. I have reset a few times and nothing helped. Are my drivers out of date or is there a new update i need. Also the HP support assist says i have an update to need to install but when i install it nothing happens... -
Reset Surface Pro 4 Software / now have errors
in Windows 10 SupportReset Surface Pro 4 Software / now have errors: I was having problems connecting to my work account so I tried to do a fresh install by using the "Reset" option. After entering my Bit Locker Recovery key it seemed to do what I was looking for. However there were some failures in the Windows update. You would think Windows...
