Windows 10: Surface pro does not turn off USB power
Discus and support Surface pro does not turn off USB power in Windows 10 Drivers and Hardware to solve the problem; I have tried all the suggestions, but as usual, none of them actually work. I want the USB power to be removed when the surface pro goes to sleep.... Discussion in 'Windows 10 Drivers and Hardware' started by ChrisAlfred, May 5, 2020.
Surface pro does not turn off USB power - Similar Threads - Surface pro does
Power up surface pro
in Windows 10 GamingPower up surface pro: I am unable to start my surface pro 7. Nothing works to reset it. https://answers.microsoft.com/en-us/windows/forum/all/power-up-surface-pro/f085f90b-222f-4350-9d16-ace978bc5888 -
in Windows 10 Software and AppsPower up surface pro: I am unable to start my surface pro 7. Nothing works to reset it. https://answers.microsoft.com/en-us/windows/forum/all/power-up-surface-pro/f085f90b-222f-4350-9d16-ace978bc5888 -
Surface Pro 8 Keyboard turns off the Surface when connected
in Windows 10 GamingSurface Pro 8 Keyboard turns off the Surface when connected: Just bought a surface pro 8 bundle from Costco every time I go to hook up the signature type pad the screen turn off, but when I disconnect it screen come back on. I thought it got fixed when I diagnosed it with support team but it's now doing it again. Very frustrating I... -
in Windows 10 Software and AppsSurface Pro 8 Keyboard turns off the Surface when connected: Just bought a surface pro 8 bundle from Costco every time I go to hook up the signature type pad the screen turn off, but when I disconnect it screen come back on. I thought it got fixed when I diagnosed it with support team but it's now doing it again. Very frustrating I... -
Surface Pro 3 Will not turn off--keeps rebooting
in Windows 10 Drivers and HardwareSurface Pro 3 Will not turn off--keeps rebooting: I have a Surface 3 Pro. Bought it on Ebay, so I really don't know any background history with it. But it has a problem of restarting about 75 percent of the time. I noticed the problem when the battery kept running down. Come to find out when I thought I was turning it off,... -
Surface Pro 4 keyboard turning on and off
in Windows 10 Drivers and HardwareSurface Pro 4 keyboard turning on and off: I have a surface pro four, and the keyboard it came with that I've been using since I got it suddenly started acting up, about an hour ago. It's been turning on and off, at seemingly random intervals, even though I've done what others have suggested for simmilar problems... -
how do I turn usb power off?
in Windows 10 Customizationhow do I turn usb power off?: I want to ensure USB port power is off when my computer is in the sleep mode. How do I do this? https://answers.microsoft.com/en-us/windows/forum/all/how-do-i-turn-usb-power-off/3e510ca5-06df-4e97-8170-4f5b9ca67e13 -
Surface Pro 4 m3 won't turn off and BSOD Power state failure drive
in Windows 10 BSOD Crashes and DebuggingSurface Pro 4 m3 won't turn off and BSOD Power state failure drive: Every time I try to turn off my Surface pro 4 from the windows menu it doesn't do anything. The restart button work but I always get a BSOD of power state failure drive. I have all drivers updated, I've tried multiple times to reset it, but it always fails from the BSOD... -
Power down button does not completely turn computer power off
in Windows 10 Performance & MaintenancePower down button does not completely turn computer power off: I recently upgraded Windows 7 to Windows 10. When I power down the system from the menu, my computer does not completely turn off. The procedure I use is described below: Click Windows_Start_button > Power > Shutdown The system closes applications and appears to...
