Windows 10: Switching sound devices causes distortion/repeated sound
Discus and support Switching sound devices causes distortion/repeated sound in Windows 10 Drivers and Hardware to solve the problem; Hey guys, I'm having a weird issue with switching between my onboard audio and my Sound Blaster Z. Whenever I set the latter to be the default... Discussion in 'Windows 10 Drivers and Hardware' started by Azhrei, Mar 1, 2017.
Switching sound devices causes distortion/repeated sound - Similar Threads - Switching sound devices
Windows Direct Sound is causing sound distortion in SDRSharp
in Windows 10 GamingWindows Direct Sound is causing sound distortion in SDRSharp: I posted my question few days ago on reddit asking about SDRSharp distortion that happens after few seconds, as is shown in a video of the link above. I figured out that the problem is caused when I set sound output to Windows Direct Sound. With MME has no problem. But MME is... -
in Windows 10 Software and AppsWindows Direct Sound is causing sound distortion in SDRSharp: I posted my question few days ago on reddit asking about SDRSharp distortion that happens after few seconds, as is shown in a video of the link above. I figured out that the problem is caused when I set sound output to Windows Direct Sound. With MME has no problem. But MME is... -
SOUND DISTORTION
in Windows 10 GamingSOUND DISTORTION: HELLO,I HAVE A HORRIBLE PROBLEM HERE, THE SOUND THAT COMES OUT OF THE SPEAKERS IS TOTALLY DISTORTED!I TRIED WITH 2 DIFFERENT SOUND CARDS... THE SAME RESULT: TOTAL DISTORTION.I HAVE LOWERED THE SAMPLING, UNINSTALL/INSTALL DRIVERS... END RESULT: THE SAME DISTORTION HERE ARE MY... -
distorted sound
in Windows 10 Gamingdistorted sound: distortion comes and goes every few sentences of song verses. Under audio it just says High definition audio speakers. Can this be something I can add to change to something better? I have uninstalled and reinstalled and it helps for 5 minutes then starts again. its an HP... -
distorted sound
in Windows 10 Software and Appsdistorted sound: distortion comes and goes every few sentences of song verses. Under audio it just says High definition audio speakers. Can this be something I can add to change to something better? I have uninstalled and reinstalled and it helps for 5 minutes then starts again. its an HP... -
distorted sound
in Windows 10 BSOD Crashes and Debuggingdistorted sound: distortion comes and goes every few sentences of song verses. Under audio it just says High definition audio speakers. Can this be something I can add to change to something better? I have uninstalled and reinstalled and it helps for 5 minutes then starts again. its an HP... -
Distorted Sound
in Windows 10 Drivers and HardwareDistorted Sound: I'm on 20H2 build SO 19042.746 but is not te problem. I've been trying to fix the distorted sound coming out of my notebook for a long time without success. In this page: https://support.microsoft.com/en-us/...a-2535c7cd56c8 at point 9 I restarted the first two services ,... -
distorted sound
in Windows 10 BSOD Crashes and Debuggingdistorted sound: the sound of my computer is wrong, it sounds very bad https://answers.microsoft.com/en-us/windows/forum/all/distorted-sound/27ae741b-4c75-40b9-8e01-c71796765919 -
Distorted Sounds
in Windows 10 BSOD Crashes and DebuggingDistorted Sounds: My sound ever since i got a new mother board got distorted. https://answers.microsoft.com/en-us/windows/forum/all/distorted-sounds/0901ceb5-0dea-458a-867f-341aedf30649
