Windows 10: System drive/system files are broken software side i think. And system reset/start-up...
Discus and support System drive/system files are broken software side i think. And system reset/start-up... in Windows 10 Software and Apps to solve the problem; hello it's since one or two moth when my pc started behave strangely: random and frequent auto reboot, some times it does stuck while the asus screen... Discussion in 'Windows 10 Software and Apps' started by Royalj, Nov 10, 2024.
  1. Royalj Win User
    hello it's since one or two moth when my pc started behave strangely: random and frequent auto reboot, some times it does stuck while the asus screen loading it's going on the start up, some other times it have big lagging moment when the reboot it's needed, some other times it completely freeze, and since almost more than one month ago it started booting with a load phrase witch says scan and restore drive c in progress...*this one have been fixed*, and some really rare times it also come out with a blue screen. so i thought about to make a restore while keeping all files and it failed be
  2. System reset.
    The challenge you're experiencing with resetting your Windows 10 PC might be due to a software conflict. It would be nice if you can tell us more about your concern. Please answer the following questions:
    • Do you have a third-party security software installed on your system? If you do have one, have you tried to temporarily disable it and see if the issue continues?
    • Have you installed the latest updates for Windows 10?
    For now, we recommend running the DISM command-line tool and the
    SFC tool to repair corrupted Windows system files that might be preventing the system reset from completing. Both tools will scan for corruptions in Windows system files and restores corrupted files. Follow the steps from this
    article
    on how to run the tools.
    Please respond back with the results.
    Devlin Sco, Nov 10, 2024
  3. System Image Problem
    [table][tr][td]Version[/td] [td]Date[/td] [/tr] [tr][td]5.05[/td] [td]8/03/2009[/td] [/tr] [tr][td]5.08[/td] [td]7/21/2009[/td] [/tr] [/table]
    Which one is newer?
    Only 5.05 was offered on HP for the machine I linked.
    The description danced around some of the anomalies we're seen with drives.
    Since only 5.05 was offered, I questioned 5.08
    Guess we know the answer now - 5.05 failed to flash.
    We could spend time trying to figure that out, but IMO it's better on the back burner for now
    I think the next step is to try the Macrium sleight of hand to get the System Image restored.
    I'd like to get the System Image up and running to do the follwoing
    • Copy Nick's data to a folder off of the restored System Image C: drive
    • run a Belarc Advisor audit to collect license keys for Nick's software
    • there might be other data collection that Nick can do in preparation for the final step
    The final step is a clean install, install up-to-date MS and 3rd party software, and restore the copied personal data.
    Nick was having difficulty locating the outlook files in the System Image - so getting it back running live is the best I can think of.
    Thoughts, suggestions, and objections are always welcome and considered
    Slartybart, Nov 10, 2024
  4. System drive/system files are broken software side i think. And system reset/start-up...
    Bill,
    Could you elaborate on the Nick's Data? I've already done a Sys Img to G: drive.
    What is a Belarc Advisor audit?
    Rebooting now to see if drives stay the same.
    Nick
    caddman6425, Nov 10, 2024
  1. System drive/system files are broken software side i think. And system reset/start-up... - Similar Threads - System drive system
  2. System drive/system files are broken software side i think. And system reset/start-up...
    System drive/system files are broken software side i think. And system reset/start-up...: hello it's since one or two moth when my pc started behave strangely: random and frequent auto reboot, some times it does stuck while the asus screen loading it's going on the start up, some other times it have big lagging moment when the reboot it's needed, some other times...
  3. Corrupted system files I think
    Corrupted system files I think: My PC has recently been having issues with disk usage and is unable to complete windows updates. It’s just on a constant loop of update and restart. I ran sfc scannow and it said there were some corrupted files it could not fix. I think this resulted from me shutting down my...
  4. Corrupted system files I think
  5. Corrupted system files I think
  6. Difference between system software and operating system software
    Difference between system software and operating system software: What distinguishes system software from operating system software? * Moved from Community Participation Center https://answers.microsoft.com/en-us/windows/forum/all/difference-between-system-software-and-operating/273dd2c1-9bd0-4ad2-9afb-f30adbc354ff
  7. Difference between system software and operating system software
  8. File system analysis software?
    File system analysis software?: Are there any softwares that can analyze every file and folder in 2 main folders to determine that their contents are identical, and if not determine the exact difference? For example if I were trying to backup a folder, but want to confirm if anything was even changed since...
  9. All my drives are System Reserved i think
    All my drives are System Reserved i think: Hello, Im trying to mod my games, but somehow i cant.First, i didnt know why. Eventually i realized, that all my drives have system Files on them. Is that the reason i cant mod the games? i heard, that games in system files are unmoddable. I hope someone can help me with...
  10. System Files on Drive
    System Files on Drive: Hi, not really sure where to put this post, and it's more curiosity than an issue. I was doing a back up onto a new 4TB external drive and noticed that the newly formatted drive had around 256 files totalling nearly 1GB before it even started. Out of curiosity, anyone know...
