Windows 10: System firmware and wifi driver code 10, wifi not showing in the dock
Discus and support System firmware and wifi driver code 10, wifi not showing in the dock in Windows 10 Software and Apps to solve the problem; I had this problem when I when my Wi-Fi turned off and I couldn’t see it in the dock, so I looked in the device manager and so that my Wi-Fi driver had... Discussion in 'Windows 10 Software and Apps' started by Mino321, Nov 10, 2024.
  1. Mino321 Win User
    I had this problem when I when my Wi-Fi turned off and I couldn’t see it in the dock, so I looked in the device manager and so that my Wi-Fi driver had a yellow error and I also saw that the system firmware had it too. I clicked properties and it said these device cannot start code 10 And on the Wi-Fi driver, it said code 43 but also code 10. I reinstalled the Wi-Fi driver and it fixed the Wi-Fi driver error but it didn’t fix the system firmware error and now it has the error on both the Wi-Fi and system firmware.
  2. ericnixmd Win User
    Networked Computers Show with WiFi - Not with Dock via Ethernet
    The dock passes the laptop's MAC, which has a reserved IP on my router. It shows as connected on my router and if I disable wifi, it will still have an internet connection (most speed I can get with wifi is 350-500 Mbps, when docked I'm getting 850-940 Mbps). I don't think ai'm
    ericnixmd, Nov 10, 2024
  3. NTM2003 Win User
    Wifi names
    I was wondering can you put anything as a wifi name for example I wanted to put CIA-outpost-#### random number is that illegal? I've seen FBI surveillance van 006 before on my list of wifi names I can pick up.
    NTM2003, Nov 10, 2024
  4. System firmware and wifi driver code 10, wifi not showing in the dock
    Problem with my wifi driver
    Hey there, I am using Asus Eeebook X205 TA with windows 10. Soon after updating to windows 10 i faced problem with my wifi driver. Whenever i wake up my laptop from sleep i see that WiFi driver just stops working showing error code 10. I have to restart
    my laptop to make it work again. I have already tried following steps -
    1. I have uninstalled and installed the driver
    2. I had tried to update the driver but it shows my driver is up to date.
    3. i have even reached Asus support page to find updated driver but that page does not have WiFi driver listed.
    I want to draw your attention on one point that it cause problem only when i put my laptop to sleep or if i put my laptop idle for about half an hour otherwise it is working fine.
    Please help me asap as I am so frustrated because of this.
    JasmeetMonga, Nov 10, 2024
  1. System firmware and wifi driver code 10, wifi not showing in the dock - Similar Threads - System firmware wifi
  2. System firmware and wifi driver code 10, wifi not showing in the dock
    System firmware and wifi driver code 10, wifi not showing in the dock: I had this problem when I when my Wi-Fi turned off and I couldn’t see it in the dock, so I looked in the device manager and so that my Wi-Fi driver had a yellow error and I also saw that the system firmware had it too. I clicked properties and it said these device cannot...
  3. Code 43 wifi not showing
    Code 43 wifi not showing: Wifi not showing at all as an option. On device adapter I have code 43 with a yellow warning . I have already tried to update , disable and then enable, disable then manually update, uninstall and then reinstall. None of which work. Wifi options don't show at all. Closest I...
  4. Code 43 wifi not showing
  5. System Firmware [CODE 10]
    System Firmware [CODE 10]: Greetings,I checked my device manager to see if there are some issues with my brand new laptop, because some thing didn't feel right was a little bit slow and unresponsive.I have an Asus Rog Strix G15 G513RM.I opened my device manager and saw that the System Firmware's update...
  6. System Firmware [CODE 10]
  7. Wifi option not showing after install wifi Driver
    Wifi option not showing after install wifi Driver: I have installed windows 10 in my laptop. After some days when I use internet then wifi not showing. How to solve this issue. https://answers.microsoft.com/en-us/windows/forum/all/wifi-option-not-showing-after-install-wifi-driver/e26e6f70-819c-45cd-bcf2-1aa774c6adf9
  8. WIFI & BLUETOOTH DRIVERS NOT STARTING CODE 10
    WIFI & BLUETOOTH DRIVERS NOT STARTING CODE 10: Himy wifi & bluetooth adapters are not working on my notebook. This is the second time this has happened after a windows update.I've tried a number of methods but still not working:update drivers.uninstall & reboot.system restore.I've downloaded latest manufacturers...
  9. Wifi and Bluetooth Driver not showing on windows 10
    Wifi and Bluetooth Driver not showing on windows 10: My Asus Laptop X441UV was not showing my Bluetooth and wifi driver even in the device manager. I can only use my internet through Ethernet cable because when I click the network icon it only shows Airplane mode.[ATTACH][ATTACH] In the device manager, my Bluetooth and Wifi...
  10. Networked Computers Show with WiFi - Not with Dock via Ethernet
    Networked Computers Show with WiFi - Not with Dock via Ethernet: Any tips as to why my networked devices show up when on WiFi but not when connected to ethernet via my Dell USB WD15 dock? I cannot figure it out no matter how hard I have looked. I'm sure there is something simple I'm overlooking. 91559
