Windows 10: System has not been booted with systemd as init system PID 1. Can't operate. - How to fix...
Discus and support System has not been booted with systemd as init system PID 1. Can't operate. - How to fix... in Windows 10 Software and Apps to solve the problem; Hello everybody!I've upgraded to Windows 11 and installed WSL2 Kali/Parrot OS, some programs work fine but others won't start and I get the following... Discussion in 'Windows 10 Software and Apps' started by RrTo4, Dec 2, 2021.
System has not been booted with systemd as init system PID 1. Can't operate. - How to fix... - Similar Threads - System has been
How to fix "operating system boot mode change 021"
in Windows 10 GamingHow to fix "operating system boot mode change 021": Hi, the HP laptop suddenly shows the message "Operating System Boot Mode Change 021" with the option Code + Enter to complete or ESC to continue without changing. I have not initiated any change, so I always press ESC. After that, Windows 10 runs normally. However, the next... -
in Windows 10 Software and AppsHow to fix "operating system boot mode change 021": Hi, the HP laptop suddenly shows the message "Operating System Boot Mode Change 021" with the option Code + Enter to complete or ESC to continue without changing. I have not initiated any change, so I always press ESC. After that, Windows 10 runs normally. However, the next... -
in Windows 10 CustomizationHow to fix "operating system boot mode change 021": Hi, the HP laptop suddenly shows the message "Operating System Boot Mode Change 021" with the option Code + Enter to complete or ESC to continue without changing. I have not initiated any change, so I always press ESC. After that, Windows 10 runs normally. However, the next... -
Can't select operating system in operating system selection
in Windows 10 GamingCan't select operating system in operating system selection: I tried to download Windows 10 on my laptopI had Windows 7 as a second operating system. After 1st reboot the operating system selection screen appears with no operating system to select. I also can't use the recovery environment. How to fix it without usb drive?... -
in Windows 10 Installation and UpgradeCan't select operating system in operating system selection: I tried to download Windows 10 on my laptopI had Windows 7 as a second operating system. After 1st reboot the operating system selection screen appears with no operating system to select. I also can't use the recovery environment. How to fix it without usb drive?... -
How to fix loading Operating system
in Windows 10 GamingHow to fix loading Operating system: How to fix loading Operating system in my PC, I restarted my PC and after restarting, it shows reboot and select proper boot device after that, I unplugged my PC and start it again because I panicked. And after starting, the error showed which is loading operating system... -
in Windows 10 Software and AppsHow to fix loading Operating system: How to fix loading Operating system in my PC, I restarted my PC and after restarting, it shows reboot and select proper boot device after that, I unplugged my PC and start it again because I panicked. And after starting, the error showed which is loading operating system... -
in Windows 10 BSOD Crashes and DebuggingHow to fix loading Operating system: How to fix loading Operating system in my PC, I restarted my PC and after restarting, it shows reboot and select proper boot device after that, I unplugged my PC and start it again because I panicked. And after starting, the error showed which is loading operating system... -
in Windows 10 GamingSystem has not been booted with systemd as init system PID 1. Can't operate. - How to fix...: Hello everybody!I've upgraded to Windows 11 and installed WSL2 Kali/Parrot OS, some programs work fine but others won't start and I get the following error message:System has not been booted with systemd as init system PID 1. Can't operate.If I try to use service then Linux...
