Windows 10: System has not been booted with systemd as init system PID 1. Can't operate. - How to fix...
Discus and support System has not been booted with systemd as init system PID 1. Can't operate. - How to fix... in Windows 10 Gaming to solve the problem; Hello everybody!I've upgraded to Windows 11 and installed WSL2 Kali/Parrot OS, some programs work fine but others won't start and I get the following... Discussion in 'Windows 10 Gaming' started by RrTo4, Dec 2, 2021.
  1. RrTo4 Win User
    Hello everybody!I've upgraded to Windows 11 and installed WSL2 Kali/Parrot OS, some programs work fine but others won't start and I get the following error message:System has not been booted with systemd as init system PID 1. Can't operate.If I try to use service then Linux does not recognize the service command.Have any of you a solution for this issue?
    RrTo4, Dec 2, 2021
  2. ' choose an operation system to start"
    Hi Bob,
    To better assist you, do let us the complete message that you receive.
    Sometimes, this could be due to two operating system installed in your computer. Just to make sure this is not the case, I suggest you to try the steps below:
    1. Press Windows key + R.
    2. Type msconfig and press enter.
    3. Click the "boot" tab and check if there are any other operating system listed.
    4. In addition, change the timeout time to 3 seconds(default)
    Let us know the result, we will be glad to help if you need further assistance.
    Wungraileng Vashi, Dec 2, 2021
  3. Error: "An operating system wasn't found. Try disconnecting any drives that don't contain an operating system"
    Hi Stephen,
    I realize the inconvenience you are facing in accessing the operating system. Now that you have me with you let me take care of this.
    Do let us know if you are able to see Windows 7/ Windows 10 operating system while rebooting the device?
    As you are unable to boot the operating system, this issue might have occurred when the boot files are missing or corrupted.
    I suggest you re-built the boot rec by following the below commands and check if it helps.
    You will have to use Windows 10/7 installation media to follow the steps to boot into Recovery Environment and try to rebuild BCD.
    Step 1: I suggest you to create an installation media for
    operating system using the media creation tool
    If system boots to Windows 10:
    Installing Windows 10 using the media creation tool
    If system boots to Windows 7: Download Windows 7 Disc Images (ISO Files)
    Step 2: After preparing the installation media, insert it hard reboot the device and follow the below:
    • Boot into Windows Recovery Environment using the Windows 10/7 installation media.
    • Click on Repair your computer.
    • Click on Troubleshoot and in the Advanced options.
    • Select Command Prompt. Type the following commands into the prompt and press Enter key after each command.
    • bootrec /fixmbr
    • bootrec /fixboot
    • bootrec /scanos
    • bootrec /rebuildbcd
    5. Restart the computer.
    NOTE: Modifying BIOS/ complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting
    from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
    Hope it helps. Reply to the post with an updated status of booting the operating system for further assistance.
    Deepika Gowda, Dec 2, 2021
  4. System has not been booted with systemd as init system PID 1. Can't operate. - How to fix...
    LionHeart1974, Dec 2, 2021
  1. System has not been booted with systemd as init system PID 1. Can't operate. - How to fix... - Similar Threads - System has been
  2. System has not been booted with systemd as init system PID 1. Can't operate. - How to fix...
    System has not been booted with systemd as init system PID 1. Can't operate. - How to fix...: Hello everybody!I've upgraded to Windows 11 and installed WSL2 Kali/Parrot OS, some programs work fine but others won't start and I get the following error message:System has not been booted with systemd as init system PID 1. Can't operate.If I try to use service then Linux...
  3. Error "CPU has been disabled by the guest Operating System" VMware
    Error "CPU has been disabled by the guest Operating System" VMware: I am not able use VMware after after updating windows a few days. It shows the error "CPU has been disabled by the guest Operating System". I tried uninstalling and then installing the software, I have also ensured virtualisation is enabled in the BIOS and also followed the...
  4. How to fix This operation has been cancelled due to restrictions in effect on this...
    How to fix This operation has been cancelled due to restrictions in effect on this...: I tried contacting one of the Windows Advisor and he gave me a fix but it didn't work. Please help asap. Thanks https://answers.microsoft.com/en-us/windows/forum/all/how-to-fix-this-operation-has-been-cancelled-due/7786a54a-6d5e-4b67-a069-4d9c41836f82
  5. Fix VMware operating system not found Boot error
    Fix VMware operating system not found Boot error: [ATTACH]VMware applications are some of the most popular for creating and managing virtual machines. […] This article Fix VMware operating system not found Boot error first appeared on TheWindowsClub.com. read more...
  6. How to Change Operating system
    How to Change Operating system: How to Change Window Phone, Window Operating system into Android operating System. Phone (Microsoft Lumia 640 xl Dual Sim) https://answers.microsoft.com/en-us/windows/forum/all/how-to-change-operating-system/55af8dba-f940-4e95-bb93-d8470e599967
  7. Can't find Operating System
    Can't find Operating System: I am running Windows 10 and Ubuntu 18 on separate partitions. When I start the laptop I get a screen saying 'Cannot find operating system' with a button to shutdown. When I restart holding f12 to choose a boot disk I kit enter for the internal hard disk. This will load grub...
  8. how to fix your system has been not modified nero install
    how to fix your system has been not modified nero install: how to fix your system has been not modified nero install, help[ATTACH] https://answers.microsoft.com/en-us/windows/forum/all/how-to-fix-your-system-has-been-not-modified-nero/b0149059-6a98-4bd8-8dba-85d956393db9
  9. can't find operating system
    can't find operating system: Tried to clean hard drive for another family member to use an old computer. Now no operating system was found. What do I do? https://answers.microsoft.com/en-us/windows/forum/all/cant-find-operating-system/d7294bc7-2652-4b0b-ac2f-462016d8e828"
  10. Switch Operating Systems In Dual-Boot System
    Switch Operating Systems In Dual-Boot System: Dual-boot system Partition C:\ = Windows 10 Pro Partition E:\ = Windows 7 Pro Would it be possible to switch the OSs? I have applications to clone one partition to another but my concern are the already installed apps being functional. Did a Google search and all I found...
