Windows 10: System Sounds keeps reverting to max volume after using Snipping Tool
Discus and support System Sounds keeps reverting to max volume after using Snipping Tool in Windows 10 Ask Insider to solve the problem; Mostly the title. This just started happening today. Last update was like 4 days ago so this is super weird. Usually I keep "System Volume" at 5%... Discussion in 'Windows 10 Ask Insider' started by /u/Kougeru, Sep 27, 2020.
  1. System Sounds keeps reverting to max volume after using Snipping Tool
    Usually I keep "System Volume" at 5% because that shit is loud AF and really sharp. 5 years with no issues and now this happens. This wouldn't be a real issue if not for the fact that I use snipping tool about 100 times a day lul
    submitted by /u/Kougeru
    [link] [comments]
  2. snipping tool
    Your post is unclear. Please post a step-by-step description of what you are doing, e.g. like so:
    • Open the snipping tool
    • Click "New"
    • etc.
    Frederik Long, Sep 27, 2020
  3. "System Sounds" slider in volume mixer Resets to Max Volume when notification happens.
    It still resets to max volume upon notification, but only when the "App volume and device preferences" window is no longer open. (just like the mixer)
    If the "App volume and device preferences" windows stays open, the "system sounds" volume does not max out upon notification.
    Ocean Skye, Sep 27, 2020
  4. System Sounds keeps reverting to max volume after using Snipping Tool
    the system sound volume stops maxing out and other system sounds remain at an acceptable volume, but I stop hearing all notification sounds, including the ones I want to hear (just more quietly), hence my idea about editing all the sounds to be quieter even
    at max volume.
  1. System Sounds keeps reverting to max volume after using Snipping Tool - Similar Threads - System Sounds keeps
  2. Is there a way to snip a straight line using the snipping tool?
    Is there a way to snip a straight line using the snipping tool?: I'm trying to snip something that's shaped like a hexagon and it's pretty much impossible to keep a straight line with my mouse to snip it and still look good. I've searched all over and can't find an answer anywhere. I hope this is allowed here, I can remove it if it's not...
  3. System Sounds volume resets to max default value Win10 2004
    System Sounds volume resets to max default value Win10 2004: Hello, since the 2004 update I have this issue the volume of system sounds resets to max value of the speaker. Every other app so far is working fine. Only System Sounds has this issue. The following I've tried does not work at all: -Set the volume via the volume mixer -Set...
  4. System sounds unmutes themselves and volume maxes out
    System sounds unmutes themselves and volume maxes out: I ran into a lot of issues last month, after being forced to update my windows version. Every time I take a screenshot, or get a notification, I always get those annoying sounds, so I mute system sounds. After closing Volume Mixer, System Sounds unmute themselves and also...
  5. "System Sounds" slider in volume mixer Resets to Max Volume when notification happens.
    "System Sounds" slider in volume mixer Resets to Max Volume when notification happens.: I keep my "system sounds" at a low volume but not muted via the "volume mixer" when i get a notification, the "system sounds" slider resets back to 100%. only while the mixer is closed, not when opened and all system sounds become painfully loud, and a pet bird was startled...
  6. SNIP SNIP TOOL
    SNIP SNIP TOOL: Does anyone know where my screen snips are saved? I can't find it in files. I really don't know where they go Like I can't screenshot using Windows+prt sc while my laptop is in 360 degrees. It is bothersome....
  7. Remove Max volume sound
    Remove Max volume sound: Hi, Every time i set the sound volume to max on my computer it start playing an annoying sound that i reached max. I use several audio sources and have volume controllers on both the browser, computer and the speaker. But as soon as i get over 90+ it just repeat the same...
  8. Cannot use snipping tool
    Cannot use snipping tool: HI all : I click on the snipping tool that I have pinned to my task bar , It opens on the 4 th monitor , in a small box . I can't click new . see the picture . thanks . I would really like to have this feature back ... [img] 111445
  9. System sounds volume keeps resetting to 100%
    System sounds volume keeps resetting to 100%: I'd like my system sounds slider to stay at 10% of the overall volume. All other volume settings seem to stick. Windows rememebers my overall / winamp / browser etc. volume just fine. Only the system sounds revert to EAR-SPLITTINGLY LOUD at seemingly random times. Sometimes...
  10. System keep reverting
    System keep reverting: ok so..i know i shouldnt have even tried...but i did. i tried plexturbo 3. i wasnt using any previous version, but it sounded too good to be true. i made a restore point and installed. after instal and restart, my asrock drivers started going crazy, not loading and giving...
