Windows 10: There was a problem starting V0790Pin.dll
Discus and support There was a problem starting V0790Pin.dll in Windows 10 Installation and Upgrade to solve the problem; After updating the Windows to Version 1909 I get this error when starting the computer. Allso another problem occured which might be connected:... Discussion in 'Windows 10 Installation and Upgrade' started by alex511, Jul 3, 2020.
  1. alex511 Win User
    Allso another problem occured which might be connected: Synaptics FP WBF Policy Service startis by itself and uses 100% CPU
  2. dalchina Win User
    Windows 10 1709 System Restore problems...
    That seems to be an attempt at Option 2 in the tutorial, which requires you to
    a. Boot to a command prompt (Did you?)
    b. You then seem to be mixing steps 3,4 and 5, thus your command is incorrect.
    I suggest Option 1 is easier.
    If you still have problems, please repost listing each specific step and saying which option from the tutorial you are using. Thanks.
    dalchina, Jul 3, 2020
  3. Shuyin03 Win User
    New here and seeking for help: problems with graphic card
    Thanks very much lilhasselhoffer. I'll start doing what you suggested step by step.
    One question thou: you suggested me to Download the latest driver package from Nvidea. However, the link you posted is for the newly released GeForce GTX 760? Am I supposed to download the drivers for that card?
    Sorry for my questions. As I said, I'm not an expert at all.
    Shuyin03, Jul 3, 2020
  4. dmccoy Win User
    Nvidia driver problem with 940 MX on Windows 10 x64
    I would only go back to the driver from the computers manufacturers if you experience any issues with the latest drivers from devie manufacturers.
    If everything is still working well with the clean boot then you can start troubleshooting as follows to start:
    How to determine what is causing the problem after you do a clean boot
    1. Log on to the computer by using an account that has administrator rights.
    2. From Start, search for msconfig. (In Windows 10, use the Search box from the Start menu. In Windows 8 or 8.1, swipe in from the right edge of the screen, and then tap Search. Or, if you are using a mouse, point to the lower-right corner of the screen, and then click Search.)
    3. Select msconfig or System Configuration from the search results.
    4. Tap or click the Services tab, and then tap or click to select the Hide all Microsoft services check box.
    5. Tap or click to select the upper half of the check boxes in the Service list.
    6. Tap or click OK, and then tap or click Restart.
    7. After the computer finishes restarting, determine whether the problem still occurs.
    • If the problem still occurs, repeat steps 1 through 6, but clear the lower half of the check boxes in the Service list that you originally selected.
    • If the problem does not occur, repeat steps 1 through 6, and select only the upper half of the remaining check boxes that are cleared in the Service list. Repeat these steps until you have selected all the check boxes.
    • If you still experience the problem when only one service is selected in the Service list, this means that the selected service causes the problem, and you should go to step 11. If no service causes the problem, go to step 8.
    8. Repeat steps 1 and 3 in this section.
    9. Tap or click the Startup tab, and then tap or click to select the upper half of the check boxes in the Startup Item list.
    10. Click OK, and then click Restart.
    • If the problem still occurs, repeat steps 8 and 9, but clear the lower half of the checked boxes in the Startup Item list that you originally selected.
    • If the problem does not occur, repeat steps 8 and 9, and select only the upper half of the remaining check boxes that are cleared in the Startup Item list. Repeat these steps until you have selected all the check boxes.
    • If you still experience the problem after only one Startup Item is selected in the Startup Item list, this means that the selected Startup Item causes the problem, and you should go to step 11. If no Startup Item causes this problem, a Microsoft service probably causes the problem. To determine which Microsoft service may be causing the problem, repeat steps 1 through 7 without selecting the Hide all Microsoft services check box in each step.
    11. After you determine the startup item or the service that causes the problem, contact the program manufacturer to determine whether the problem can be resolved. Or, run the System Configuration utility, and then tap or click to clear the check box for the problem item.
    From <https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows>
    dmccoy, Jul 3, 2020
  1. There was a problem starting V0790Pin.dll - Similar Threads - was problem starting
  2. DLL problems
    DLL problems: I have a lot of dll problems, I tried system file checker, manual install, third party dll fix software, and Windows reinstall 11 pro n. Nothing works, I can't install DirectX runtime it keeps giving errors... honestly I don't know what to do next...... Nothing seems to do...
  3. DLL problems
  4. there was a problem starting dll the specified module cannot be found
    there was a problem starting dll the specified module cannot be found: there was a problem starting dll the specified module cannot be found https://answers.microsoft.com/en-us/windows/forum/all/there-was-a-problem-starting-dll-the-specified/a738667a-5551-48e0-87bb-13164a3a8f36
  5. there was a problem starting dll the specified module cannot be found
  6. there was a problem starting dll the specified module cannot be found
  7. "There was a problem starting printui.dll. A dynamic link library DLL initialization...
    "There was a problem starting printui.dll. A dynamic link library DLL initialization...: I cannot add printer to my system. And all I got is this error prompt.There was a problem starting printui.dllA dynamic link library DLL initialization routine failed.How to fix this?...
  8. Problem with MSVCP110.dll & MSVCR110.dll
    Problem with MSVCP110.dll & MSVCR110.dll: Hello, Sorry for my bad english, i'm french I don't know since when, but now I can't read any DVD/Blu-Ray and even movies in .ISO. I'm sure it was working 1 month ago. Usually, I use PowerDVD20 to open such files, but since today, i get an error: [ATTACH] also the same...
  9. Dll files problem
    Dll files problem: I installed windows 10 (x64) on my pc (pentium @ 2.9 GHz, 6gb ddr3 Radeon HD 5450 1gb) from a USB drive I made a while back(I used it a few times with no problem on different pcs). But now, I get errors with dll files when I try to run almost any game. (and my storage is...
  10. Problem with a DLL
    Problem with a DLL: I did it "https://support.microsoft.com/en-us/help/929833/use-the-system-file-checker-tool-to-repair-missing-or-corrupted-system" and after a day it is came back (the problem) and now i am to do it again and it wont work help!...
