Windows 10: Trying to connect two monitors to my PC using HDMI split adapter. Not detecting both screens
Discus and support Trying to connect two monitors to my PC using HDMI split adapter. Not detecting both screens in Windows 10 Drivers and Hardware to solve the problem; Please help. I'm using the adapter with both HDMI cord from each monitor. However its only showing two displays. My computer and one of my monitors.... Discussion in 'Windows 10 Drivers and Hardware' started by krystal_594, Oct 3, 2019.
Trying to connect two monitors to my PC using HDMI split adapter. Not detecting both screens - Similar Threads - Trying connect monitors
both monitors are on but my pc doesnt detect the 2nd i have both screens duplicated
in Windows 10 Software and Appsboth monitors are on but my pc doesnt detect the 2nd i have both screens duplicated: i have got a hdmi splitter for my pc in the hopes to extend my display. both displays are connected and working but they are only duplicated. i went into display settings to change it but i couldnt and when i click detect the pc is unable to detect the 2nd monitor even though... -
How to connect two additional monitors to a laptop using an HDMI splitter?
in Windows 10 GamingHow to connect two additional monitors to a laptop using an HDMI splitter?: I have two monitors plugged into an HDMI splitter, which is plugged into my work laptop. Although both monitors are connected, the laptop will only detect one at a time. Each monitor works if it is the only monitor connected, but when both monitors are connected, only one... -
in Windows 10 Software and AppsHow to connect two additional monitors to a laptop using an HDMI splitter?: I have two monitors plugged into an HDMI splitter, which is plugged into my work laptop. Although both monitors are connected, the laptop will only detect one at a time. Each monitor works if it is the only monitor connected, but when both monitors are connected, only one... -
HDMI not detecting monitor
in Windows 10 GamingHDMI not detecting monitor: Hi,I am WFH at the moment and have been using my laptop and Dell monitor for a dual screen, it was working fine first thing this morning but Windows then did some form of update and now the monitor is not being detected through the HDMI cable, I tried this with another cable... -
in Windows 10 Software and AppsHDMI not detecting monitor: Hi,I am WFH at the moment and have been using my laptop and Dell monitor for a dual screen, it was working fine first thing this morning but Windows then did some form of update and now the monitor is not being detected through the HDMI cable, I tried this with another cable... -
External monitor connected and detected, but no HDMI signal
in Windows 10 Drivers and HardwareExternal monitor connected and detected, but no HDMI signal: Hi All,I purchased a Acer Predator Triton 500 model PT515-52 laptop, with an RTX 2070S with Max Q, running Windows 10. I have a Samsung external monitor that I have been using with my other laptop, which is an ASUS Zenbook. As soon as I plug in this laptop, the external... -
Split Screen Using the Same Monitor
in Windows 10 Ask InsiderSplit Screen Using the Same Monitor: While I realize having multiple screens using multiple monitors is possible, I am also wondering if it is possible to use one screen as though it were two monitors. Say you have one large monitor, using Windows 10 would it be possible to convert that single monitor so it... -
split screen not Detecting
in Windows 10 Drivers and Hardwaresplit screen not Detecting: I have a VGA splitter for my 2 monitors, when i go into settings to try and detect my screens it shows no detection's. I've tried to update drivers but it shows i have the latest update. i'm lost and frustrated cant get my 2 monitors to split. can someone help?... -
Monitor not detecting a signal from the computer using a DisplayPort adapter to HDMI cable
in Windows 10 Drivers and HardwareMonitor not detecting a signal from the computer using a DisplayPort adapter to HDMI cable: I have XPS13 and recent purchase of thunderbolt docking station tb16. all are dell products (laptop, docking and monitors) . The 3rd monitor is not detecting a signal from the computer using a DisplayPort adapter to HDMI cable that leads to the docking station (since for...
trying to connect 2 screen displays to docking station using displayPort & DVI cable
