Windows 10: Two monitor system - How to make monitor 2 my primary monitor
Discus and support Two monitor system - How to make monitor 2 my primary monitor in Windows 10 Drivers and Hardware to solve the problem; Two monitor system - How to make monitor 2 my primary monitor... Discussion in 'Windows 10 Drivers and Hardware' started by poorbob, Jan 24, 2019.
Two monitor system - How to make monitor 2 my primary monitor - Similar Threads - monitor system monitor
Two Monitors
in Windows 10 Drivers and HardwareTwo Monitors: I have Windows 10 Home edition and would like to run two monitors. Presently I have two monitors plugged in and working but they show the same picture on both. I would like to be able to run different programs on each.I know there is a feature that lets the user label the... -
Two monitors
in Windows 10 Drivers and HardwareTwo monitors: I set up my computer with two monitors. Now my main monitor keeps reverting to #2 and my second smaller monitor is #1. How do I change it back or can I? https://answers.microsoft.com/en-us/windows/forum/all/two-monitors/d65b6e9d-404b-4b0a-bd12-9c6730983432 -
Two Monitors
in Windows 10 CustomizationTwo Monitors: I had two monitors working on my computer and the second one stopped working after an update. I switched HDMI cords and check all connections still not working. Maybe the HDMI Driver needs updating?? Thank you for your help. John... -
two monitors
in Windows 10 Customizationtwo monitors: I recently hooked up a second external monitor to my Dell Laptop due to the fact that I am forced to work from home now. Both monitors work, but I can't figure out how to have each monitor display something different, nor can I get an app to "slide" to the other screen, it... -
Two monitors.
in Windows 10 Drivers and HardwareTwo monitors.: I have a gaming PC and a 144 hertz monitor. A main game I play usually runs at around 240 frames per second. I found an old monitor from 2009 in my garage. When I saw it I attempted to set it up as an extra monitor for doing stuff on the side. After I set it up, I tried... -
Two monitors
in Windows 10 BSOD Crashes and DebuggingTwo monitors: I have 2 monitors connected to PC. Is it possible to use them both on the same time. They must communicate. As example: Open picture on screen 1. Move that picture to screen 2. Open file again and display another picture on for screen 1. Both screens now with different... -
Two Monitors
in Windows 10 CustomizationTwo Monitors: Why will Windows 10 not recognize my 2 Monitor? When I ask to detect my 2nd Monitor, I get not recognized from Windows 10. https://answers.microsoft.com/en-us/windows/forum/all/two-monitors/71a83057-d4ae-4864-8f2c-98f4aa9e7403 -
Two monitors
in Windows 10 Graphic CardsTwo monitors: I connected two monitors to my Lenovo H50-55. One with a Vga cable, the other with an HDMI cable. The size of the monitors is different but resolution is the same. One is an LG analog the other an insignia digital set to fit the screen. Now I have both running (more or less)... -
Two Monitors
in Windows 10 SupportTwo Monitors: Newbie question re setting up two monitors: is it possible to a different program running on each monitor, e.g., to have an Acrobat file up on one and SketchUp running on the other? If so, can someone tell me how? The dual monitor set up options I've found don't include what...
monitor 2 primary
