Windows 10: TYPING PROBLEM IN MS EDGE, SETTINGS, AND START MENU !
Discus and support TYPING PROBLEM IN MS EDGE, SETTINGS, AND START MENU ! in Windows 10 BSOD Crashes and Debugging to solve the problem; Hello Microsoft, Three days ago, I've formatted my LENOVO laptop with Windows 10 _ 1809 Edition. after a few hours of setting it up, I noticed... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by AymanFahd, May 4, 2019.
TYPING PROBLEM IN MS EDGE, SETTINGS, AND START MENU ! - Similar Threads - TYPING PROBLEM EDGE
New Ms edge and Old Ms edge lies in same in start menu.
in Windows 10 CustomizationNew Ms edge and Old Ms edge lies in same in start menu.: Hello, Iam a windows user after installing microsoft edge on my PC. the old ms edge cant hidden. You can see in the screenshot. I want to remove the old ms edge. Plz help[ATTACH]... -
Start Menu and ms-settings don't work
in Windows 10 CustomizationStart Menu and ms-settings don't work: Greetings, When I woke up and turned on my PC everything was normal but, when I signed in everything was black I can move my cursor around and open task manager but nothing else. After a few minutes, the desktop loaded and now I cannot open the start menu and any of the... -
Can't type in start menu?
in Windows 10 Ask InsiderCan't type in start menu?: After Windows automatically restart to install their amazing new update, I can no longer type in the start menu. I have tried nearly all fixes I have found online, including reinstalling Cortana and running ctfmon.exe, but none of it has worked. This issue only started when... -
Typing search in start menu still goes to Edge
in Windows 10 SupportTyping search in start menu still goes to Edge: I have set my default browser as Firefox but if I type a search in the start menu it still opens Edge (with Bing). Is there any setting that I can use to say always use FF even when I do a search? I have Googled endlessly and all I can find is how to set the defaults. Many... -
weird problems with start menu and settings
in Windows 10 Ask Insiderweird problems with start menu and settings: Its my first post in this subreddit so be kind. I do tech support, so for me this one is weird In the last couple of days my main win10 machine has problem with the start power icon having no effect(right clicking works) and if i go to settings i can't type anything into the... -
start menu, setting menu, ms edge not working
in Windows 10 Customizationstart menu, setting menu, ms edge not working: i have a surface pro 2017 i5 128GB very low responding and windows keep updating very often, so i decided to do a reset delete all files, i didn't do the backup since i think that setting etc was not best after reset, i found the start menu, setting menu, search, not... -
Start menu/task bar ms-settings broken
in Windows 10 BSOD Crashes and DebuggingStart menu/task bar ms-settings broken: Hello I just did a factory reset of my Surface pro(5th gen) and now clicking/touching the start menu icon or pressing it on my keyboard doesn't work. The buttons on the bottom right of the taskbar are also unresponsive but pinned apps work. Trying to open ms-settings:... -
Start Menu and Settings problems.
in Windows 10 CustomizationStart Menu and Settings problems.: After applying the most recent forced update my start menu no longer works. Clicking on the button or attempting to type into the search bar does not function and there is a significant decrease in performance. What I've tried so far to fix it: 1. Restarting the... -
Start Menu / Settings / Edge / Cortana - None are working...!
in Windows 10 CustomizationStart Menu / Settings / Edge / Cortana - None are working...!: Hi - I'm having trouble with windows on my Surface Pro. I'm using Windows 10 Version 1803 (OS Build 17134.165). On my toolbar the following items are unresponsive to left clicks: Start Menu Cortana Any items in the far right corner (calendar, wifi, battery, etc)...
