Windows 10: unusual HP print/scanner problem-CHKDSK fail! help pls
Discus and support unusual HP print/scanner problem-CHKDSK fail! help pls in Windows 10 Gaming to solve the problem; HI all, am trying to fix a family PC with a 3 in 1 HP . its all good so far. sudden recent scanner fail- message is scanner not detected or not... Discussion in 'Windows 10 Gaming' started by mikkyg, Nov 23, 2022.
unusual HP print/scanner problem-CHKDSK fail! help pls - Similar Threads - unusual print scanner
in Windows 10 Software and Appsunusual HP print/scanner problem-CHKDSK fail! help pls: HI all, am trying to fix a family PC with a 3 in 1 HP . its all good so far. sudden recent scanner fail- message is scanner not detected or not compatible.did all usual things, check cords/cables -replugged, rebooted..etc. looked at My PC, printers/scanners, checked Device... -
in Windows 10 Drivers and Hardwareunusual HP print/scanner problem-CHKDSK fail! help pls: HI all, am trying to fix a family PC with a 3 in 1 HP . its all good so far. sudden recent scanner fail- message is scanner not detected or not compatible.did all usual things, check cords/cables -replugged, rebooted..etc. looked at My PC, printers/scanners, checked Device... -
backlight problem pls help
in Windows 10 Customizationbacklight problem pls help: how can i turn on my lights on the laptop it doesnt work fn+f3/f4 can someone help me woth that? i have a asus rog strix laptop https://answers.microsoft.com/en-us/windows/forum/all/backlight-problem-pls-help/c8777b01-0b14-4df0-94cb-e1d2bef5700e -
Pls help "problem with XMRig"
in Windows 10 BSOD Crashes and DebuggingPls help "problem with XMRig": I don't even know what a XMRig is. It opens automatically every time I start computer and if I close it, it reopens. When I open task manager it disappears. It is not in startup programs and I can't find it using search. My ram is only 4GB and as soon as this program started... -
Pls Help / Mic Problems
in Windows 10 Ask InsiderPls Help / Mic Problems: i have a laptop Acer Aspire ES1-523 , windows 10. i has only one jack so im using a jack splitter and i inserted the external microphone and the external headphones. The problem is that my laptop picks up the audio coming out of the headphones ( the "listen to this device" is... -
HP ENVY FINGER PRINT SCANNER NOT WORKING
in Windows Hello & LockscreenHP ENVY FINGER PRINT SCANNER NOT WORKING: After a recent update, my fingerprint scanner does not work on my HP ENVY x360 running Windows 10. I have done all of the recommendation, uninstalled and reinstalled the drivers. Made sure I had all the recent updates, yet Windows Hello Fingerprint still stats that this... -
unusual HP printing problem with win 10
in Windows 10 Drivers and Hardwareunusual HP printing problem with win 10: my edition of windows 10 is vs 1903 . when I open up a doc or email the printer works fine., if I do a screen grab to .png - it will not print when fully open on the screen using my HP printer officejet 5255 . .. but if I save it to a file and then go to that- folder / file... -
Finger print scanner on hp envy
in Windows Hello & LockscreenFinger print scanner on hp envy: I have windows 10 and window hello installed. But when I set it up I didn't activate the fingerprint scanner it said I could do it later. Later, i went into the sign in section in setting and found that windows hello was activated. The option for the facial recognition was... -
ADMINISTRATOR PROBLEM pls help
in Windows 10 Installation and UpgradeADMINISTRATOR PROBLEM pls help: The first email address i used for my microsoft account is no longer accessible so i wanted to change it to my current email add. So i made a new account on my PC (WIN 10), and transferred the admin rights to the new account. But apparently after i did, i accidentally deleted...
