Windows 10: USB connected and reconnected sound keeps repeating even when no USB’s are connected HELP
Discus and support USB connected and reconnected sound keeps repeating even when no USB’s are connected HELP in Windows 10 Ask Insider to solve the problem; I just got this PC a few days ago and the sound you get when you plug in a USB and disconnect it keeps repeating over and over. I have tried a few... Discussion in 'Windows 10 Ask Insider' started by /u/Tennacity, Aug 4, 2020.
USB connected and reconnected sound keeps repeating even when no USB’s are connected HELP - Similar Threads - USB connected reconnected
USB Connecting/Disconnecting Sound
in Windows 10 Drivers and HardwareUSB Connecting/Disconnecting Sound: Hi! Would like to ask help because my PC has been making a USB Connected/Disconnected sound repeatedly and it's been getting pretty annoying. I tried disconnecting all devices in my USB ports, however the sound still persisted. I have muted it for the meantime as it is... -
in Windows 10 GamingUSB Connecting/Disconnecting Sound: Hi! Would like to ask help because my PC has been making a USB Connected/Disconnected sound repeatedly and it's been getting pretty annoying. I tried disconnecting all devices in my USB ports, however the sound still persisted. I have muted it for the meantime as it is... -
in Windows 10 Software and AppsUSB Connecting/Disconnecting Sound: Hi! Would like to ask help because my PC has been making a USB Connected/Disconnected sound repeatedly and it's been getting pretty annoying. I tried disconnecting all devices in my USB ports, however the sound still persisted. I have muted it for the meantime as it is... -
windows connect/disconnect sound repeating for USB device
in Windows 10 Drivers and Hardwarewindows connect/disconnect sound repeating for USB device: This has happened a few times for me now. I found the fix, so I'm sharing it. I have fixed it each time by vacuuming out the port on the computer and the the USB wire end. Must have been a piece of dust or something interfering with the connection. Hope this helps you.... -
in Windows 10 Gamingwindows connect/disconnect sound repeating for USB device: This has happened a few times for me now. I found the fix, so I'm sharing it. I have fixed it each time by vacuuming out the port on the computer and the the USB wire end. Must have been a piece of dust or something interfering with the connection. Hope this helps you.... -
in Windows 10 Software and Appswindows connect/disconnect sound repeating for USB device: This has happened a few times for me now. I found the fix, so I'm sharing it. I have fixed it each time by vacuuming out the port on the computer and the the USB wire end. Must have been a piece of dust or something interfering with the connection. Hope this helps you.... -
USB Disconnect sound keeps repeating
in Windows 10 Drivers and HardwareUSB Disconnect sound keeps repeating: About every 3 seconds the usb disconnect sound plays. Im not unplugging anything or plugging anything in. This started when I updated Windows earlier. I looked around and saw something about unplugging all usb devices and plugging them back in, and when i tried that windows... -
No sound when connecting and disconnecting USB devices
in Windows 10 Drivers and HardwareNo sound when connecting and disconnecting USB devices: There's no sound when I connect and disconnect USB devices. The sounds used to work until one or two weeks ago. I am not sure if the other event sounds work or not, but I can use media players without issues. If I check the Sounds tab under Settings, I can see the event... -
USB Connect/Disconnect Sound
in Windows 10 Drivers and HardwareUSB Connect/Disconnect Sound: Go to Control Panel/Sounds/Sounds tab. scroll down to Device Connect and Device Disconnect. If there isn't a sound associated with it, (ie) a speaker icon next to it, then choose the Browse button and choose whatever sound you want. Default is Windows Hardware Insert, and...
