Windows 10: USB port works **** in noise sounding every second, with usb icon flash in lower panel
Discus and support USB port works **** in noise sounding every second, with usb icon flash in lower panel in Windows 10 Software and Apps to solve the problem; 90% of the time, my laptop plays an audible error sound every second or two and the usb port symbol flashes in the bottom right panel. When I adjust... Discussion in 'Windows 10 Software and Apps' started by Emma Coote, Sep 26, 2022.
USB port works **** in noise sounding every second, with usb icon flash in lower panel - Similar Threads - USB port works
Second Monitor Flashes On and Off with USB Disconnect Sound
in Windows 10 GamingSecond Monitor Flashes On and Off with USB Disconnect Sound: My desktop PC is somewhere in the 6-8-years-old range. I've used a second monitor for years for work with no problems. The last few weeks, every single time I turn it on or log back in from it being in Sleep Mode, the second monitor flashes on and off. Every time it flashes,... -
in Windows 10 Software and AppsSecond Monitor Flashes On and Off with USB Disconnect Sound: My desktop PC is somewhere in the 6-8-years-old range. I've used a second monitor for years for work with no problems. The last few weeks, every single time I turn it on or log back in from it being in Sleep Mode, the second monitor flashes on and off. Every time it flashes,... -
in Windows 10 GamingUSB port works **** in noise sounding every second, with usb icon flash in lower panel: 90% of the time, my laptop plays an audible error sound every second or two and the usb port symbol flashes in the bottom right panel. When I adjust the laptop screen this can change the alert to either return or sometimes briefly disappear.I have noticed that my laptop... -
in Windows 10 BSOD Crashes and DebuggingUSB port works **** in noise sounding every second, with usb icon flash in lower panel: 90% of the time, my laptop plays an audible error sound every second or two and the usb port symbol flashes in the bottom right panel. When I adjust the laptop screen this can change the alert to either return or sometimes briefly disappear.I have noticed that my laptop... -
USB ports not working
in Windows 10 Software and AppsUSB ports not working: Here comes my challenge... My laptop just shuts down while working even when it have more battery life.. Now my USB ports are only working when the lid is closed. When I open the lid they stop working.... Help please... -
USB port not work
in Windows 10 Software and AppsUSB port not work: HI ihave a USB port in my notebook HP Pavilion dv6700 not work,so icheck in the registry REGEDIT and foe some reazon the USB is not in the registry,I did HKEY-LOCAL-MACHINE/SYSTEM/CurrentControlSet/Services/USB to se if the DisableSelectiveSuspended if is dere but the USB is... -
USB Ports disconnecting every 5 minutes for 5 seconds.
in Windows 10 CustomizationUSB Ports disconnecting every 5 minutes for 5 seconds.: So ever since i updated my windows a few days ago, my usb ports which has my headset, keyboard and mouse connected to it disconnects for 5 seconds then connects itself back and this occurs every 5 minutes. I have tried every method of leaving usb ports running when pc is on... -
USB ports , drivers and Flash Player
in AntiVirus, Firewalls and System SecurityUSB ports , drivers and Flash Player: I have lost two drivers (or usb ports) and am unable to use flash player . These incidents have all happened right after a Windows 10 update. Not sure what to do... -
'USB device not recognized' flashes every 10 seconds.
in Windows 10 Drivers and Hardware'USB device not recognized' flashes every 10 seconds.: hello, i have got the acer laptop with windows 10 per-installed. the laptops was working fine and i had no problem with it. then i got a major update. i used a usb mouse and when i disconnect the mouse the message started to flash saying 'USb device not recognized' making...
