Windows 10: USB port works **** in noise sounding every second, with usb icon flash in lower panel
Discus and support USB port works **** in noise sounding every second, with usb icon flash in lower panel in Windows 10 Gaming to solve the problem; 90% of the time, my laptop plays an audible error sound every second or two and the usb port symbol flashes in the bottom right panel. When I adjust... Discussion in 'Windows 10 Gaming' started by Emma Coote, Sep 26, 2022.
  1. USB port works **** in noise sounding every second, with usb icon flash in lower panel
    90% of the time, my laptop plays an audible error sound every second or two and the usb port symbol flashes in the bottom right panel. When I adjust the laptop screen this can change the alert to either return or sometimes briefly disappear.I have noticed that my laptop camera is also affected by this - "we cannot find your camera"I have completed the updates that were recommended to me, and I expect this may be a hardware fault of some kind. Is there anything I can do to be sure?The laptop is a Porsche Design Ultra One, and I have no idea how I would get support from them.
  2. Arun B J Win User
    USB Ports Not Working
    Hi Jemjames,
    I understand your concern and will assist you to resolve this issue.
    Method 1: Troubleshoot
    Windows 10 has a built-in troubleshooter to check and fix issues with hardware and devices. I would suggest you to run this troubleshooter to check if the issue is with your USB. Refer these steps:
    • Press Windows key +X, select Control panel
    • Change the view by option on the top right to Large icons
    • Run the Hardware and devices troubleshooter
    Method 2.
    Try updating the latest USB devices from the manufacturer's website and check if the issue persists.
    Follow the steps to update the USB drivers:
    a. Press Windows key + X key and click Device Manager.
    b. Expand the USB driver.
    c. Right-click on the USB and click on Update driver software.
    d. Restart the computer and check.
    Hope this helps. If the issue remains unresolved, please get back to us and we would be happy to help
    Arun B J, Sep 26, 2022
  3. USB Ports Not Working
    Hi Patrick,
    Thank you for keeping us updated.
    • Have you tried suggestions provided by Hamilton Apolinario?
    If not, please re-install Windows 10 and check the status. If the issue still persists, I suggest you to get the hardware diagnostic done from the manufacturer.
    Step 1: Download the Windows 10 ISO (using another computer so you can use USB ports to transfer files)
    Refer to the article below and download Windows 10 ISO using Media Creation Tool.
    Download Windows 10
    Step 2: Make a USB flash drive bootable
    Refer to the article to download Windows USB/DVD Download Tool to transfer ISO to USB flash drive to make it bootable device.
    Important: Ensure there is no data in USB flash drive before making it bootable device. If you have any data, back it up accordingly.
    Disclaimer: Please keep a backup of your data in case of loss.
    Hope this information is helpful. Please feel free to reply in case you face any other issues with Windows in future.
    Niranjan Manjhi, Sep 26, 2022
  4. Arun B J Win User
    USB ports not working
    I understand your concern regarding the issue that you are facing
    I suggest you to follow the steps below and check if it helps
    Method 1: Run Hardware and Devices Troubleshooter
    Follow these steps to run Hardware and Devices troubleshooter:
    • Press Windows key + X and click on
      Control Panel.
    • Select Troubleshooting.
    • Select View all on the top left corner.
    • Click Hardware and Devices.
    • Follow the on-screen instruction to run the troubleshooter.
    Method 2:
    Update USB Controllers.
    To update the USB Controllers from Device Manager follow these steps.
    • Go to Device manager in control panel.
    • Select Device manager and a Device Manager window will pop-up.
    • Double Click on USB Controllers to expand.
    • Right click on the USB Controllers that is listed and select Update.
  1. USB port works **** in noise sounding every second, with usb icon flash in lower panel - Similar Threads - USB port works
  2. USB port works **** in noise sounding every second, with usb icon flash in lower panel
    USB port works **** in noise sounding every second, with usb icon flash in lower panel: 90% of the time, my laptop plays an audible error sound every second or two and the usb port symbol flashes in the bottom right panel. When I adjust the laptop screen this can change the alert to either return or sometimes briefly disappear.I have noticed that my laptop...
  3. USB port works **** in noise sounding every second, with usb icon flash in lower panel
  4. USB ports not working
    USB ports not working: Here comes my challenge... My laptop just shuts down while working even when it have more battery life.. Now my USB ports are only working when the lid is closed. When I open the lid they stop working.... Help please...
  5. USB ports not working
  6. USB ports not working
  7. USB port not work
    USB port not work: HI ihave a USB port in my notebook HP Pavilion dv6700 not work,so icheck in the registry REGEDIT and foe some reazon the USB is not in the registry,I did HKEY-LOCAL-MACHINE/SYSTEM/CurrentControlSet/Services/USB to se if the DisableSelectiveSuspended if is dere but the USB is...
  8. USB Ports disconnecting every 5 minutes for 5 seconds.
    USB Ports disconnecting every 5 minutes for 5 seconds.: So ever since i updated my windows a few days ago, my usb ports which has my headset, keyboard and mouse connected to it disconnects for 5 seconds then connects itself back and this occurs every 5 minutes. I have tried every method of leaving usb ports running when pc is on...
  9. usb ports not working
    usb ports not working: hey my name is sami and ive been experiencing some real issues with this asus laptop 8gb ram it has 2 usb ports* months ago i lost one of them but the weird thing is that it could read my external hdd but noting else and when i plug my mouse in only the lights work but not...
  10. 'USB device not recognized' flashes every 10 seconds.
    'USB device not recognized' flashes every 10 seconds.: hello, i have got the acer laptop with windows 10 per-installed. the laptops was working fine and i had no problem with it. then i got a major update. i used a usb mouse and when i disconnect the mouse the message started to flash saying 'USb device not recognized' making...
