Windows 10: Volume on 1809 resets to 30 after power-down / power-up
Discus and support Volume on 1809 resets to 30 after power-down / power-up in Windows 10 Installation and Upgrade to solve the problem; My PC was recently upgraded to 1809. Every time I power-down and power back up, the volume resets to 30, when it was previously set to 15. This... Discussion in 'Windows 10 Installation and Upgrade' started by nobody-important, Dec 14, 2018.
Volume on 1809 resets to 30 after power-down / power-up - Similar Threads - Volume 1809 resets
Shut down power during resetting
in Windows 10 Software and AppsShut down power during resetting: I reset the computer and I accidentally shut the power downI try winre and troubleshooting, I can’t reset the progress and repairAnd I can’t use winre anymore again even serveral method I can’t even go to login screen It keep blinking and hp sign It keeps having hard disk... -
in Windows 10 GamingShut down power during resetting: I reset the computer and I accidentally shut the power downI try winre and troubleshooting, I can’t reset the progress and repairAnd I can’t use winre anymore again even serveral method I can’t even go to login screen It keep blinking and hp sign It keeps having hard disk... -
in Windows 10 Installation and UpgradeShut down power during resetting: I reset the computer and I accidentally shut the power downI try winre and troubleshooting, I can’t reset the progress and repairAnd I can’t use winre anymore again even serveral method I can’t even go to login screen It keep blinking and hp sign It keeps having hard disk... -
Stuttering/Skipping after power down
in Windows 10 BSOD Crashes and DebuggingStuttering/Skipping after power down: Hello Microsoft community, I've been having an incredibly frustrating issue ever since updating to windows 10. About a two months ago I dug an older computer out of the closet and decided to update it so to start using it. Prior to windows 10 this issue never happened. As... -
Shut down laptop to battery power and power up when reconnected?
in Windows 10 BSOD Crashes and DebuggingShut down laptop to battery power and power up when reconnected?: Hello, I wanted to ask if there is a way to shut down my Windows 10 laptop immediately when it is disconnected from the power supply and automatically restart it when it is loaded. I only closed it in the closet (connected via WLAN) and wanted to control it with a WLAN... -
Powering down PC resets BIOS
in Windows 10 Drivers and HardwarePowering down PC resets BIOS: Hi guys, weird issue here and hoping someone has any ideas to why. I typically remove power from my PC whenever I go out of town due to power outages that sometimes plague my area (yes, I have a UPS, still…). Down time here was 3 days. Anyway, after restoring power and... -
power down
in Windows 10 Performance & Maintenancepower down: app preventing shutdown https://answers.microsoft.com/en-us/windows/forum/all/power-down/89091f3d-eb7c-405e-a430-b334c506ebf0 -
Asus X552CL laptop boots up but powers down after exactly 30 minutes every time
in Windows 10 Performance & MaintenanceAsus X552CL laptop boots up but powers down after exactly 30 minutes every time: Anyone know any fixes for this issue? One of the problems is by the time it is booted up, there is only about 25 minutes to work on it before it switches off... -
Power & Volume Icons
in Windows 10 SupportPower & Volume Icons: How do I show the power icon and volume icons on the taskbar notification area? I have tried properties - customize - turn system icons on or off But the power/battery and volume icon are greyed out. Win 10 pro (upgraded from Win 7 Pro) 29017
